Here is the stock and added ground and current pics... sorry for how dirty the engine is... 8 years old this may... 500a92a1902d2c39d01b88d7b50e8fb1.jpgf39b6c9c6b5555c94a3d457e43857ff2.jpg3377a2ff96987d2a94e86429263576b4.jpgd532bf9566214da44382d0bcc99beb69.jpgc68b4bc9d99b6bc5345c7bd506643a33.jpg18aacca1197a1473bbc488ff6c093a11.jpg913c81923a251808eb3594eb5e1ea2b8.jpg
@Gr8FrozenNorth : did you ever complete this operation of adding the auxiliary battery and increasing the alternator capacity?
I just purchased a 2021 2500HD LT and they "forgot" to install the package or couldn't due to missing parts.  Anyway I have the parts ordered and a new 220 volt alternator on the way and will be doing this mod in a few weeks when everything arrives.
My truck arrived with the 170 Amp Alternator but has a 250 amp fuse for the alternator on the main battery.  For a 170 amp alternator this would normally be a 175 amp fuse.  For some reason my fuse block is from a 1500 Diesel with a 220 Alternator - for me, that is a good thing :)
I purchased the " J Block Auxiliary Battery"  84663447 - this part comes with a 30 amp fuse, a 100 amp fuse and a 175 amp fuse.  The 100 amp fuse is connected to an isolator relay all as one assembly.  The cover is Junction Block Cover 84471670
I am re-using the cable from the main battery positive to the terminal on the X50D (175 amp) it runs from the main battery over to the X50A Fuse Block (as per normal) and then a short pigtail will run from that connection to the 100 AMP fuse on the auxiliary battery J Block (X50E).  this is the fuse attached to the isolator.
The isolator is supposed to be powered from a secondary relay that wires into a connector X136.  I have to find all that on the truck first but I am away on business so it will take a bit.  right now I am still in research mode but it looks like that is pretty much it other than connecting the trailer 30 supply power wire up.
From reading the battery relay will energize if you switch to tow/haul mode and it will charge the aux battery.
maybe someone with the factory install would have more intel.  I will post pictures once things get underway.
I'm wondering if anyone has had their dealer do an install much like the factory install? I just put a deposit on an in transit SLE with the Snow Plow Prep so I will have the 220A alternator. I would just need the battery, the new junction/fuse box and the additional leads. I know as a factory install its like a $135 install but looking at the parts list it looks significantly more as an after the fact installation. I just wasn't sure if there was a retrofit kit for the dealer to order of if you need to identify and order the individual parts needed.
My new 3500HD gas truck arriving next week will have the factory dual battery installation.  If you would like me to post photos of anything let me know.  I'm going to be immediately installing 6awg wire to a slide in camper connector (for a 30 amp DC-DC converter/charger in the camper), so figuring out the battery, isolator, and fuse block arrangement on the truck will be one of the first things I get into.
  • 3 months later...
Please do post the set up.
Yes, please post pics of your factory dual battery set up.  Now that you've had it a few months are you happy with its performance?  I have a 22 GMC HD ordered with that option and I'm very anxious to see what it looks like from the factory.
I will take some pictures later this evening. I have not yet wired anything to the second battery. I ordered the option because it was way cheaper than adding the battery system later, and eventually I’ll use it to power an air compressor or refrigerator or both. The factory wires the trailer 12 volt supply to the aux battery. No other loads are on it right now, so I can’t give a report on using the aux battery yet.
From research I've done recently including chatting in another forum with a guy that has a 2020 Chevy HD with the factory dual batteries I believe that the second battery powers the trailer connections (4 pin and 7 pin) when the truck is turned off and when the truck is running both batteries get charged.  That way you can power your RV with the truck off and not worry about draining your starting battery.  He traced the wiring using schematics he found online and then tested his truck with a meter to confirm it.  I haven't been able to check it myself yet but he seemed to be confident and knowledgeable on what he was talking about.  Is that aligned with your understanding?
I believe all of that is correct except my understanding is that only the trailer positive (pin 4) is powered from the aux battery, and pin 7 is reverse lights.  That’s my understanding of standard 7 pin trailer connector wiring, but I have not tested pin 7 to see how it’s actually wired on my truck.
Did a quick search and found the below diagram.  It will be interesting to know which pins have power when the truck is completely off.
I just used a voltmeter and confirmed that only pin 4 has 12 volts on it when the truck is off and no lights are on.
i’m not sure what you would like pictures of, so to start here is a view of the general battery installation and one of the i fuse block. The 30 amp fuse is connected to pin 4 of the trailer connector. The 100 amp fuse comes from the main battery fuse block.
My truck has a gas engine with single alternator. The aux battery option includes a larger 220 amp alternator. My understanding is that on diesels the second battery is a parallel wired starter battery with no isolator.
Edited by Another JR
Another JR, hey thanks for checking the volts and confirming that only pin 4 is hot.  Also, the pics are great.  I just wanted to see what the factory set up looks like.  The aux battery definitely fills the hole that is in that corner of the engine bay when the battery isn't there. I like that it's wired so the aux battery is disconnected without us needing to do anything.
Edited by 03 Cobra
  • 5 weeks later...
Hi all according to my dealer I should have my 2022 Silverado 2500HD in 2 weeks. (I have a build date of 8/30/21!)
 I ordered the dual Battery/Alternator option. Dose anyone on here know how this setup works? (Just incase my dealer is not suer) Is one battery just for the truck and one for a camper? I have had dual battery setup in some of my other vehicles but I installed them with a battery isloator. I plan on having a slide in pop up truck camper that I will be putting to good use this winter! Im from Michigan so its south or west for me! Thanks all! I posted this in other sections a lot of views but no reply....
HDHP
On the dmax they are all dual the batteries which behave as one big one.
Not sure about on the gasser
Edited by redwngr
HDHP
On the gas trucks the aux battery is charged when the truck is running.  When the truck is off only pin 4 on the 7 pin round trailer connections is powered by only the aux battery (it is disconnected from the starting battery when the truck is off).  This way you can power your camper or other items using the 7 pin connector(s) without draining your main battery.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
