2k19Sierra Posted February 22, 2020 Posted February 22, 2020 Anyone find a clean way to install a light bar on the front of the sierras yet? I know rough country has nice solution for the Silverado but I haven’t seen anything for the Sierra yet... looking at the front end this morning and see a couple potential fastening locations, though they are higher up on the grille then ideal... looking for ideas!
jeepincbum11 Posted February 24, 2020 Posted February 24, 2020 I went lower with mine. Had to fabricate a mount. Took a couple hours. Still need to wire it up. Sent from my SM-G960U using Tapatalk 1
2k19Sierra Posted February 24, 2020 Author Posted February 24, 2020 19 minutes ago, jeepincbum11 said: I went lower with mine. Had to fabricate a mount. Took a couple hours. Still need to wire it up. Sent from my SM-G960U using Tapatalk Love that, any close up photos of how you mounted it?!
jeepincbum11 Posted February 24, 2020 Posted February 24, 2020 Love that, any close up photos of how you mounted it?! I put a aluminum bar across the supports that the angle iron lays on top of. I'll try to get better pics tmrw.Sent from my SM-G960U using Tapatalk 1
jeepincbum11 Posted February 24, 2020 Posted February 24, 2020 Basically I cut a 34 inch aluminum L bar and mounted it with self tapping screws to the two lower air dam supports. I then ran L brackets with holes in it from the light to rest on the aluminum. Self tapped the two together for each side. It doesn't have to line up perfectly as the light side is adjustable. I did ensure the aluminum support bar was level. Sent from my SM-G960U using Tapatalk 1
jflan23 Posted February 24, 2020 Posted February 24, 2020 I went high with mine. I was able to bolt them right to the bumper. Also, once you cut that huge plastic trim piece into two pieces, it’s way easier to handle lol. 1
jeepincbum11 Posted February 29, 2020 Posted February 29, 2020 Well,. I ended up not wiring to the high beams. I purchased a 12v 433mhz remote control relay from Amazon. Wired the light bar to it and it to the battery. Programmed the homelink button to the remote like a garage door opener. No wires needed to route through the firewall. Link to relay. 12V Remote Control Switch 40A Power Switch Radio Controller, Wireless RF Receiver Switch 3000W 433Mhz Remote 2 Transmitter and Receiver,Wide Voltage DC12V - 48V https://www.amazon.com/dp/B07XK7D73Q/ref=cm_sw_r_cp_apa_i_q6CwEb7EHP941Sent from my SM-G960U using Tapatalk 1
Dersch Posted January 4, 2022 Posted January 4, 2022 On 2/24/2020 at 5:40 AM, jeepincbum11 said: Basically I cut a 34 inch aluminum L bar and mounted it with self tapping screws to the two lower air dam supports. I then ran L brackets with holes in it from the light to rest on the aluminum. Self tapped the two together for each side. It doesn't have to line up perfectly as the light side is adjustable. I did ensure the aluminum support bar was level. Sent from my SM-G960U using Tapatalk I see what you did here and i like it my question is there a way to put the bar behind the bumper instead of infront if that makes sense?
GMCSierra99 Posted January 4, 2022 Posted January 4, 2022 (edited) This is what I did. Mounted them with 3M Auto Double sided tape. Sorry for the salt, got to love MN winters. Edited January 4, 2022 by GMCSierra99 1
