Trans temp gauge install
Alright so I've got the routing planned out for the sender. My question is with a 2003 Silverado can i simply use one of those "add a link" fuse holders to tap into the interior fuse panel for wiring if an electrical aftermarket gauge (autometer)?
If so which fuse is for constant and which could I use for switched ign power?
Check bbbindustries.com I believe it is. Last I knew they had free wiring diagrams still. Doesn't the dash cluster have a trans temp gauge? I've heard if not there's ways you can have it added to the cluster or swap the cluster and have it turned on in the ecm. Is this for everyday driving, racing application or something else?
Sent from my SM-N975U1 using Tapatalk
(If this post is too long I apologize, please scroll to last sentence for my question)
Thanks for replying, my truck didn't come with a trans temp gauge or factory trans cooler. I've seen the replacement clusters you speak of which run roughly $200 where they send you a complete replacement cluster with the option of LEDs to the color your choice, an optional replacement bezel and for an additional price they send you one with a OEM trans temp gauge in it which is supposed to be plug and play.
They have one that you order and send yours in as the core. Another company has you send your cluster in to be soldered with new LEDs with the same options available as above for a slightly lower price. Pretty dang cool...
Since I already have an electric trans temp gauge (Autometer) on my work bench I'd like to install that in the Silverado.
I've read a bit about using Retained accessory power, put there for upfitters that's located by my left foot in the center of cabin near the parking brake for ignition switched accessories. But I plan on using that down the line for accessories that draw more power like Auxiliary lights, amps, etc.
I was just wondering which fuses in the interior fuse box are switchable with the ignition and not always hot.
More specifically I'm wondering where others are running their aftermarket gauges to for switched power?
Grab a test light and start poking around.
I always use an underhood fuse as those tend to be better for switched power. Any of the o2 sensor fuses are switched and I've used those many times.
Not looking to tap in under the hood. Looking for a switchable fuse inside the cabin. Thanks for your input though.
Update: For other members looking for a switched 12V (ignition on only) power source inside the cabin fuse box: The SEO ACCY fuse (10A) is unused according to factory service manual.
This is on a 2003 Silverado
It provides switched 12V power. Hope this helps someone. It's the one below my finger in the picture
