Input - HD front springs and Z71 Pkg.
MesaRat
spent the entire afternoon at the dealership trying to get the truck aligned.  they are telling me something is wrong with my truck and they can't get it aligned, possibly the frame is out of spec. they claim they tried two different alignment racks.   i just can't believe this.  they are calling GM and I just opened a case number.
Did they tell the issue they were having?  If the thrust angle is out, there is no adjustment on that and would require a leaf spring swap.
The other issue I have seen is with the diesel trucks the front axle is so heavy you have to be very careful to center the front tires on the bearing plates other the bearing plates will be loaded when they release the steering wheel lock and the steering will kick causing the toe to be out.  This will cause the steering wheel to be off.
#iworkforGM
1 hour ago, davester said:
Where exactly are "bearing plates" on the front end of GM pickups, for the front wheels to be centered on?
Bearing plates I think he is referring to the alignment rack.  The front wheels sit on plates that rotate so you can caster sweep the front end properly.
#iworkforGM
the issue is the truck keeps pulling to the right.  i have not asked them about the thrust angle but will mention it along with the bearing plates, thanks for the suggestions.  i have asked them about measuring the frame and checking it against spec and they are getting back to me.
they spent all day working on it and spoke with GM.  they told me they aligned the truck so it would have a hard pull to the left.  when they tested it, it still pulled to right.  GM has instructed them to replace the steering box.
That is correct.
Steering gear replacement may fix it as well.
#iworkforGM
#iworkforGM
steering gear seemed to take care of the problem/pull.
however, after i left noticed there was a bit more play in the wheel (on center).  i looked for the adjust screw but can't seem to find one.  was hoping to give it just a fractional turn.
Dealership adjusted steering box and it is now good - no pull and no play.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
