Absurd lead time for FOX 2.5 shocks
3 minutes ago, tyler.frost92 said:
Nice, what are you getting from deaver? Full pack?
Just the J1 for now. If it dont cut it i'll get a custom set of U182's made that only lift 1-2 inches
I was contemplating getting the same, but adding long travel shackles. Gotta see how it does on my first dune trip in June.
I have the J1 mini pack on my 2018.  I removed the factory overload spring and installed the mini pack with the factory block. I have the 4 1'2" CST lift with there coil overs. Lift came with a 3" block which I didn't use. Truck sits level and rides super nice. You really notice the difference on the uneven joints on the highway.
If I end up doing the j1 I plan on removing the factory overload, adding the long travel shackles (basically a 1 or 2 inch drop shackle) then adjusting the height with the small shims it comes with to hopefully end up at stock rear height.
Sent from my iPad using Tapatalk Pro
which shackles are you thinking about using? I was hoping to use the U182's with a hanger to drop it back down but was told by DirtKing that their Shackle only drops it half an inch.
Dirt king or camburg most likely. If I have to remove the factory block or get a shorter one to get the height I'm looking for I will
I saw someone who did this and took two of the 3/8" spacers out of the J1 leafs.
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 605 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
