  • 1 month later...
I think you be fine unless you are planning to buy some China made tires. Just remember to read the ad copy carefully.
I have bought used and new. All good experiences. Always remember though if the price is too good to be true, it usually is (cough cough counterfeit). The one issue I had on a tire was a used one. It appeared to have been squished in some way that put a small curve in the sidewall. It probably would have been fine to run, but I contacted the seller and they sent another like-new of the same tire at no cost, and had me keep the "bad one". Excellent seller in that instance.
  • 8 months later...
for peace of mind i would honestly rather get tires from a trusted chain store. i would not like to place my trust off tires i can buy over the internet to save just a few bucks. did you end up getting them OP? any updates?
  • 1 month later...
Did a couple years ago and regretted it.  The were ATV and the ad said they were radial tires as what came on the Honda. Tires they sent were not.  Each tire was shipped separately by UPS. So they authorize I can exchange them but I can only get 1 return label and UPS would not accept all 4 tires with one label as no way to track them if they become separated.  I had to pay to ship 3 back.  So moral of the story, go to local tire shop and pay their price, probably cheaper in the long run.
Another high cost online tire purchase, friend order 4 tires from Tire Rack who had a local dealer installer.  The local dealer took him for $175 to mount and balance the tires, $100 more or less then he could bought same tire from the GY dealer.
Edited by elcamino
I’ve bought probably 7-10 sets of tires and wheels off eBay. Literally comes down to the place your buying from, I’ve pretty much used the same 2 “stores” and gotten much better prices than my local ass tapping tire guys.
heck discount tire has a store on eBay, you’ll be fine.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
