Check engine light on my 2015 Sierra 1500 came on today giving a P0446 evaporative emission system vent control electrical circuit code, and was trying to decide what’s the best way to go about it before buying any parts. Should I take it to the dealer or just any mechanic? Heard it’s a pretty common issue but not sure where to start or how to test anything.
Most common failure is the vent valve itself and the part probably costs less than the diag charge. If you know someone with a bi-directional scanner you can command it open and closed. If it makes noise more than likely it's fine. If not you need to check for power and ground at the solenoid while switching it. If no noise and good power and ground replace it.
Sent from my SM-G988U using Tapatalk
Before you get into it any deeper, make sure the gas cap is on tightly. Drive it a few times. If it doesn't clear, buy a new gas cap (they're cheap).
Edited by bigoilman
Gas caps have nothing to do with that that DTC.
Needs updated/rerouted EVAP CVS valve
It probably got junk in it, bad location from factory.
  • 8 months later...
Just had this code come up today I cleared it with my scanner to see if it comes back on.  then going to try to tighten gas cap if not will replace canister they are not too expensive and the on the purge if it remains on
Mine came on a few days ago and have been debating on taking it to a shop or trying something myself. Let me know it goes for you.
Actually it stayed off after i cleared it going see if it comes back on. Bought a $30 obd2 reader that will reset codes a few years back and has been worth every penny
Thanks for the reply. The my check engine light started flashing today and the truck started shaking so going to take it to a shop tomorrow AM.
Flashing is bad did you have the codes read?  sounds like you have more than a p0446
Only P0446 when I had it read so the others must have happened after. Doesn’t sound too exciting. Lol
I had this happen in one of my gm's twice with the flashing and shuttering.  One time it was a bad coil pack the second time the cat conv went bad and clogged up the exhaust.  If it is a coil pack or spark plug it is not too bad on cost
Took it to the shop this morning. The mechanic says cylinder 6 is misfiring so hoping it’s just the spark plug and/or coil pack. I’d hate to replace the cat converter
I'm glad to hear it is something cheaper
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
