Just wanted to post my experience with the 2020 Piston Caliper swap on a GMT800. My truck is a 2006 Z71.
The swap went pretty much flawlessly. I have seen a couple of topics on this swap on the web, but nothing on a gmt800 4wd.
ZERO modifications to the truck required ( with that being said I have 2015 Sierra 20" wheels, I doubt the stock 17" Z71 wheels will clear.) The only thing I had to do is get 4 washers, 2 for each side to center the caliper over the rotor, so the pads are not dragging on one side.
Even the screw that holds the rotor on at the factory fits in the same spot on the new rotors... lol.
Parts I used.
2019 - 2020 Silverado / Sierra 4 piston front calipers, rotors and pads.
CHECK your own clearances, I do not know if they vary truck to truck, these are what worked on mine.
The parts I got were a take off from a truck with around 5 miles on it... so the rotors and pads still required a little use to get them correct. Once I put them through a couple heat cycles, what a difference. I have yet to put new braided hoses I have. I wanted a fair comparison between the caliper swap. Hoping everything will keep working well with more miles put on them.... kind of a guinea pig here. LOL.
Edited by AlljackedupZ71
  • Like 5
Sweet upgrade! Glad it worked out easily. I definitely don't think it would fit in my 17's.
Sent from my SM-G960U using Tapatalk
  • 3 weeks later...
@AlljackedupZ71
I just did this upgrade yesterday to my 2004 Silverado and my 22" Centerline wheels will not fit over the these 4 piston calipers.  What types of wheels are you using with this upgrade?
On 5/25/2020 at 9:26 AM, tlaw91 said:
Does anyone want to buy a set? I have a few laying around
Info & Price?
Any wheel recommendations to clear the calipers for a 5/6 lowered Silverado?
I'm interested. Location and price?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
