Rough Country Hidden Winch Mount - 14-18 Sierra/Silverado
Has anyone installed one of these yet?  Looks to be fairly new and curious as to the max winch size....as in LxWxH dimensions that will fit.
https://www.roughcountry.com/gm-hidden-winch-mounting-plate-11004.html?find=2017-gmc-sierra-1500-4wd-567945
I have a 2017 Sierra 6.2/4x4/MaxTrailering and also have an older Warn HS9500i that has been sitting on the shelf for years, in new condition with dimensions: 23.12"L x 6.3"D x 9.94"H.
I have reached out to Rough Country asking this specifically and received a response of 12,000lbs - not real useful, thought the RC 12k Winch is 21.3L x 6.3D x 8.6H.
Basically, don't want to tear into my front end to find out my winch won't fit.  Would prefer to keep the winch I have...as it's one of the best Warn ever made...
Thoughts?
No experience with rough country plate, I do know that mine at 6 5/16x10 1/8 x 21 is tight.  Just have to cut more stuff.  I lost one lower bumper mount and slid tight to other one.  Will the guy who built plate one this forum cut both mounts out with no problems of loose bumper.
20 hours ago, tmo said:
0d7ba8c895752c1a34732835df509f4c.plist
Right - will accommodate most winches, but not oversized.  This winch is a bout 15 years old, but sat in a garage and is brand new.  I'm not sure if it falls into the category of "oversized" or not.
That's helpful - with yours being a little bit taller, I think I'm good to go.  I was more concerned with height and the winch getting up into something that can't be trimmed.  Thanks a bunch!
Where did you get the grill ( mesh /led light ). Look's good . Thanks
Well if the mounts is the size that is listed on the website, take a tape measure under the truck
That rough country winch looks great, I wish there was a flip down/up license plate bracket for those of us in places where it's required.
my last pic is with the license plate clipping onto the roller fairlead with conduit brackets
Sorry, I was meaning an option for the rough country version. Prob wouldn't be too hard to make something.
I knew you were talking about the RC mount. My post was just saying there would be some way to mount a plate.  If you can cut the crap out of the front of a truck to mount a winch, you can come up with a simple fix to mount a plate (-:
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 529 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
