Rear spring Block/ Factory ride height?
I have a 2020 Silverado with the max tow package.  I have a fiberglass cap and a cargoglide in the back of the truck.  It currently rides at approximately 38" from floor to fender arch on all four corners.  I don't care for how the back end looks a little saggy, so i was wondering what the factory ride height is and was hoping to put a spacer block under the rear springs to get it back to an unloaded ride height.   If anyone might be able to help me out, i would appreciate it!
Thanks
Nate
Thanks
Nate
Every single truck is going to measure a little bit different. I believe stock rake is 2-3 inches higher in the rear. in order to prevent axle wrap I personally would highly suggest airbags.
Blocks act like levers on the springs, larger blocks the more leverage the axle places on the springs in an attempt to turn the springs.
Since you bought at Max tow I assume that you plan on actually towing with it as such airbags going to help you way more than blocks with tounge weight which are going to decrease stability at Max payload.
Still will need weight distribution for full capability while towing.
Sent from my SM-N975U using Tapatalk
Topgear1224 -
Thanks for the post!  Good idea on the airbags.  i'll look into those systems some more.  And yeah I have an Airstream that I will be towing with it!
Thanks again,
Nate
Topgear1224 -
Thanks again,
Nate
The only thing that gets a little bit iffy is you have to make sure you actually weigh your truck axles. When heavily loaded, because with airbags you can actually make the truck not squat at all (tires will squat but the suspension won't), it's very easy to accidentally overload a your rear axle.
easiest and safest and also most accurate way is to just drive over a trucker scale to get your individual axle weights.
the other way I've seen people do it is they'll decrease the psi in their bags to the minimum pressure the manufacturer recommends then load their truck and watch the squat. Much less accurate but better than nothing.
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
