I have an '18 Sierra SLT 4x4 with black pack. I'm considering a ~4 inch lift with ~35s using the factory 22 inch rims. I know 18s would be cheaper but I really like my factory wheels. I just don't want the tires to be too "low-pro" for a lifted truck. Obviously it's subjective but wanted to see pics from those that have done it already.
2018 Silverado, 4 1/2” CST lift with 22x10-25 and 33x12.50/22 Toyo MT’s.
Could easily do 35’s with stock wheels or a 22x9 with a 0 offset. I just prefer the stance with the 10 wides and a 33” tire.c596593c5979306458af8b143c47af20.jpg
2 inch level in front. None in the rear. 285/50r22 and does not rub Nitto ridge grapplers
Edited by Gas Man
6" BDS with 2.5 coilovers and Deaver's with 22's and 35's. 35's still slight rub with the 6 inch lift on full lock, can only imagine 35s with a 4"...
My 4 1/2” CST will clear 35’s easier then the BDS 6” since it’s a bracket lift not a knuckle lift. It doesn’t increase the track width.
  • 5 months later...
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
