dunnjew Posted June 7, 2020 Posted June 7, 2020 Just completed a transmission flush and filter change. My trans fluid temperature now seems to be way higher than before as it just hit 196. Any clues as to what might cause this? Or a solution?
truckguy82 Posted June 7, 2020 Posted June 7, 2020 Nope, that’s what it always was there’s a trans thermostat that doesn’t open until 190
dunnjew Posted June 7, 2020 Author Posted June 7, 2020 Ok thank you, for some reason i remembered it being less
btj_z71 Posted June 7, 2020 Posted June 7, 2020 1 hour ago, dunnjew said: Just completed a transmission flush and filter change. My trans fluid temperature now seems to be way higher than before as it just hit 196. Any clues as to what might cause this? Or a solution? You can use some of this to help out. Best to use it right after a flush too. I added this and the instant shudder fix. Noticeable difference after 20-30 miles. Has to mix in with all the fluid plus get throughout the torque converter. https://www.lubegard.com/products/platinum/
CamGTP Posted June 8, 2020 Posted June 8, 2020 Do the thermostat mod and you'll drop the temps by 30-40 degrees easy.
dunnjew Posted June 8, 2020 Author Posted June 8, 2020 Can you post a link to this or point me towards some more info.thanks
CamGTP Posted June 8, 2020 Posted June 8, 2020 Remove the thermostat block from the transmission, it's only 1-2 bolts and be careful of the o-rings when you pull out the lines. My 2016 has two little o-rings anyway. Flip the pill inside like this video and that's it. I dropped my temps by 40 degrees when it was 70-80 degrees out.
