I have a 2019 LT Z71 Texas Edition with the 5.3L in it.
So far I have done mostly small cosmetic things to the ride.  Like the illuminating bow tie, black vinyl stickers on the bow ties in the steering wheel and wheels, etc.
I do have a Black Widow Venom 250 Muffler installed.
I just ordered the JLT catch can today and I kind of have the itch to do something else to the ride.
Debating on buying this but I'm so indecisive lol.
https://www.shopchevyparts.com/performance/2019-silverado-1500-air-intake-kit-performance-cold-air-53l-engine/84789802-p-92300615.html
Either that or maybe add the fog lights to the truck.  But Ehh, not sure any of these two mods will make much of a difference.
https://www.shopchevyparts.com/electronics/2019-silverado-1500-led-front-fog-light-package-models-without-task-lighting-set-lights/84125494-p-92300703.html
What do you think?
I agree! They don't claim HP numbers, but what they do claim is air flow and air restriction. They "minimize air restriction and flows 51.69% better than stock."
The GM's air intake is rated at 13% air restriction.  So in theory the S & B is 4 times better than the Gm intake. So it probably makes 8 to 10 HP compared to GM's 2 that they claim if you take it from the performance package.
When I put it on my 2018, I could truly feel the difference, and the sound was amazing.
I can't wait for mine on my 2019, and the price is fantastic for the product you are getting. I don't believe even the RotoFab flows that much air and the S & B is $170 cheaper!!  You won't be disappointed.
Yep, I already pulled the trigger on this lol.  S&B CAI comes on monday.  Wohoo!!
Ops! The Holland tunnel would flow more air yet on a test bench as a stand alone. Thing is, the motor doesn't. If this were not so then 4X more air = 4X more power not 8 hp at peak rpm at WOT. A place you visit about what? Once a year? The OEM is a CAI. On the road it will be within 2 or 3 F of ambient. In town it doesn't matter. What you buy with a CAI is noise. If you like noise then great. There are cheaper ways to get noise than a CAI.
  • Thanks 1
For what it’s worth, I saw two different people on the FB group complain about loss of throttle response with the S&B intake. Safe to assume it’s pulling timing with the stock tune, but what they feel may just be perceived.
What isn’t just perceived is the “check engine air filter” message people get in the DIC with these “open” type intakes.
Well I already have an exhaust, and the noise does sound sweet.  Next up, turbo whistle in the exhaust! lol JK
  • Haha 1
I've read and seen lots of videos that say the throttle response is improved with the S&B.  Also may just be placebo effect but ehh either way.  I could always change it out if I'm not happy with it.
Not really worried about any messages in the DIC, I know it's recommended to turn off the air filter life indicator as it won't be accurate.  Could always drop a chunk of change and get a tune :D.
All you have to do is turn off the air filter life indicator. Very simple. The S&B has a plexi-glass cover so you can see the filter condition without having to open the whole thing up.
Y’all are gonna make me get one of these S&B CAIs here soon lol
Next up on the list will be the JLT Oil Catch can and the S&B CAI
Can anyone elaborate on the difference between the difference between S&B Cold Air Intake with Dry Extendable Filter VS. the one with the oiled cotton filter?
I went with the dry one, IMO it really doesn't matter that much.  Oiled filter technically filters more but is more maintenance I think.  I've never had an oiled one so I figured dry would be the way to go with me.
After looking more into this thread, I don’t want any error messages to pop up about “check air filter” etc. also I want the air filter indicator to be accurate. Are there any direct swap CAIs that don’t affect any of these electronics?
I also have the dry one. The oiled ones can mess up the mass air flow sensor if not oiled properly.
@Grumpy Bear......that's your opinion, but I have had one of these and it makes a huge difference. Do you want to know how? Well, after racing my stepdads ecoboost, I gained a half a truck length, so you can take your ambient temperatures along with your stock air intake and grab a bowl of porridge and maybe you will be HappyBear!
Good Day!!
Also with these CAI, you must unplug the battery for 2 1/2 hours and then shut off the filter light on dash, and you won't have any problems!
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,238 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
