4-4.5 inch strut replacement Zone lift
I have a 2014 with the Zone 4.5 inch lift. It currently has the 4 inch strut spacer that comes with the kit, but after a year and a half with the lift I want better suspension performance. Does anyone know what company makes a 4-4.5 inch strut replacement? I just want to get rid of the spacer on top of the strut. I’ve looked everywhere and no luck. I know BDS has the 4 inch strut replacement that comes with their lifts, but don’t know if it would work with my Zone lift (although they are sister companies).
Yes the BDS strut will work with no problems. I'm not sure why you want to do away with the top spacer as it will allow you to run any off the shelf strut that you wish. You can also get in touch with CST for their coilovers.
Sent via Morse code
Sent via Morse code
I didn’t think about that actually. I just thought that If there’s a fully sprung strut rather that a spacer on top of it there’s my actual suspension travel and better ride quality.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
