Front Differential Fill and Drain Plug Removal?
Have an '08 Tahoe.
Looking at steel fill and drain plugs in an aluminum housing. That's not a happy mix.
Is there a technique to getting the plugs to budge?
It appears that it might be a lifetime installation
Put more force on the wrench?  Maybe use a 6-point socket to reduce the likelyhood of rounding off the head.
And use the right torque value on both when installing them.
I remember on my 02 Yukon I could not get the fill plug off so I just left it until I sold it at 120k miles. I wanted to change the fluid after 5 years. On my 18 Tahoe I just did all the fluids and the fill plug was extremely tight and rusty. I sprayed it with wd40 and let it sit for about 30 min. Then it came right off. I think the key is to take fill plugs out (at least the front) within the first couple of years so it doesn’t freeze together. Try some spray and maybe tap lightly with a hammer while you have a socket on there. It may free it up.
One other trick is to heat the housing and ice the plug and try to get it to move that way.  Don't have to heat it much since aluminum expands faster than steel. The tapping as you try to turn it out is also a good idea.  It can loosen the corrosion on the threads.  I had to do that with the lounge chairs when I recovered them.  Steel bolts into aluminum housings holding the material on .  Took some tapping but and a tighten and loosen motion but I got the bolts out.
Thanks guys.
It's too late to loosen them periodically. Never expected to have the truck this long but once we retire and the replacement cost is in the $60,000 bracket, it puts a different light on the subject.
I'll try the heat/ice process but somehow I suspect galvanic welding is in play. I guess it really doesn't matter of the bolt rounds off. It's sealed and may be staying in there.
Similar issue in the read cover but it's steel to steel and the cover is cheap enough to replace without worrying about a seized plug in the old one.
If it truly is welded together, you could always just drill it out, put in a helicoil and a new plug.  There might even be enough clearance to do it without having to remove the diff from the truck...
Thanks again. Have nothing but time around here to give things a try.
    jack-arrrdor
    jack-arrrdor
  • Who's Online   1 Member, 0 Anonymous, 1,895 Guests (See full list)
