Does anyone have a photo of the ac drain location. Can’t find the damn thing. I have to be blind
Look right above the exhaust pipe or muffler, I read where they have it drain on it to stop from leaving puddles of water on peoples garage floors. People said they can hear it hissing when they first shut off the pickup.
On your '02, it's on the passenger side firewall, and is too far away from the exhaust to drip on it.
Google "gmt800 ac drain" for pics/videos of it and how to clear it.
Sorry... not 02. Old profile pic from 18 years ago. It’s a 2020 and can’t find it. Found a parts diagram but that didn’t help
maybe update your sig as well, as it doesn't mention anything about a '20
Ah. Gotcha. None of that shows on the app.
Mine's been draining in the cab on passenger side since Friday... Thank goodness for the Weathertechs! I will be making a phone call Monday morning.
I just replied to your post. Might be more to your situation as well
  • 2 years later...
So I have the same issue. Passenger side carpet gets damp, I’ve pulled my weather tech mats and the bottom is damp just in the
Middle. When AC runs there is a good drip from The condensate line running to the pavement. (Appears to be working right) I leak tested windshield, back brake light, etc and never seen any water. The floorboard on passenger side is getting HOT. I cannot figure this out… and it’s starting to smell.
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
