Corsa performance exhaust 6.2 fit on 5.3?
So I got a deal on a corsa performance exhaust but it’s for 6.2 off 2016 Silverado..... I have a 2014 Silverado with a 5.3 would it work? I have a small exhaust leak (missing the donut where the y-pipe and manifolds meet at) so I figured I’d just swap the whole exhaust with something better wonder if this would help it or hurt? Also thinking of changing the intake to the 6.2 I think I’ve seen couple people do that on here...
It should fit Frankie the muffler clamps are the same size for the 6.2 and 5.3
I just bought a new one cause my Corsa is on back order so when the time comes I won’t worry about using the original one
Well I mean will this bolt up straight to my current 5.3 Y-pipe? Is this flex pipe bigger then the one that’s on my truck currently? This is off a 6.2 exhaust
I know all the hangers are on the same place so those will fit perfectly.
About to go take a picture of my factory setup, thanks hope it’s good got this for a really good deal don’t wana sell it if I can use it0781D106-4A8A-4412-87FF-AB3ACAD0E4C1.thumb.jpeg.f46b4e48b259433194280007fb4dd61f.jpeg
Yeah I looked it up before I bought price was like 1400/1500$
posted pictures of the current stock setup looks pretty old and thin
The 6.2 clamps is larger than the 5.3 clamp. The ball flange dealio on the cat-back is larger on the 6.2's because the overall exhaust size is larger on a factory 6.2.
But what I don't is if the corsa system used the same size clamp as the 5.3's.
Having worked in a parts store, I always have to send people to the dealership to get the 6.2 clamp because our computer system says the 5.3/6.2 clamps are the same size but with a tape measure they are clearly not the same.
Might just let the muffler shop install it, I looked up both the 6.2 (3.5in) and 5.3 (3.0in) Corsa Performance Exhaust and it’s about .5in difference so I’m wondering if the shop can make something work
Any exhaust shop could just chop your flex joint with flange and weld it straight to the corsa system if they had too.
More air out mean more horsepower right? I needa buy a cold air intake still
Save your money for gas .
I see a lot of your pics are at the pumps[emoji2957][emoji2957][emoji2957][emoji40]
Sent from my Pixel 3 using Tapatalk
Your truck looks killer Frankie [emoji106][emoji106][emoji106][emoji106][emoji40]
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 885 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
