No oil consumption issues here either, but I did order a PCV valve just for the halibut. Should have it early next week.
This was my intake valves on a 2018 sierra 5.3L. at 27k with no catch can and 0w-20 oil.   When i did my cam swap i cleaned them up and  added a catch can and switched to 0W-30 oil.   I can say the engine sounds much quieter with the 30wt and the catch can works great. Haven’t pulled the intake off agin to check if the valves are any cleaner though, however the can does capture more than i thought it would.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,336 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
