  • 5 months later...
2021 3.0 Duramax Sierra AT4
Tinted Windows
2 inch AT4 1318 Rough Country level
stubby antenna
painted exhaust tips red
Coming Monday Ridge Grappler 35x11.5
Edited by Weir003
Tinted Windows
stubby antenna
<Coming Monday Ridge Grappler 35x11.5
What tires are on it now? In the 2nd pic they already look like Ridge Grapppler's.
Are the Ridge Grappler's going to be LT or the XL Load range?  Looking to do the same on my stock 20s.
My truck came with Goodyear Territory MT 265/60/20.  The Ridgegrapplers are E rated and LT.
On 9/21/2020 at 11:46 AM, aragrev7 said:
c38159444fbff95888fe65a1f44bb2b1.jpgba6f2604bbaa1e83eb9bd70a225dd914.jpgb6ce71b77e2f05bdea6ff28a6ffacddd.jpg5949a018b4f3d73f8fa18126cff86891.jpg
2020 AT4 5.3L 10sp - Pacific Blue
Engine bolt-ons:
- Volant Cold Air Intake with PowerCore filter & Pre-filter.
- Custom True Dual Exhaust (separate pipes from headers to tips).
Exterior:
- Black textured Putco Bed Rails.
- Black Horse Off Road Armour Bull Bar (custom fit / park sensor rewire).
- Extang Xceed Tonneau Cover (Hard / 4 Panel).
- Lund Aeroskin II Hood Deflector - Textured Black Finish.
- Lund Low Profile Window Deflector - Smoke finish.
- Undercover Swing Case (Passenger).
- Custom designed Canadian Logos (Black / Red)
- Carbon Fiber Vinyl wrapped front logo.
- GMC logo hitch receiver plug.
- GMC logo Aluminum valve caps.
- GMC Cargo Net.
- Flat Step Rails (Black / Textured).
- 6.5” Stubby Antenna
- Blind Spot mirrors (side mirrors, rear view)
Tech:
- Pedal Commander
- BlackVue Front & Rear Dash Cam - Shock/GPS/Parking mode/cloud.
Interior:
- 35% Nano-Carbon Ceramic Window Tint
- 5% Nank-Carbon Ceramic Windshield Brow Tint.
- centre console tray & dividers.
- Baby seats & Skullvibe molle seat protectors : D.
Did you do badges your self? Or do you mind providing where you got them?  I would love to have maple leaf on at4 and a few other things but hard to find someone to do. Thanks, they look great!
2021. Fuel 18 x 9 plus 1offset Blitz wheels with factory Duratracs. 50 calibre style antenna. Wrapped the front GMC with carbon fibre look vinyl from Canadian Tire. Plasti dipped all the other emblems. Added a compustar T 13 remote start and dash cam. Expel on most of the front end. Dealer offered black powder coated exhaust tips installed for $200. Also had them swap out the special “carpet” floor mats which will get full of mud anyway and I don’t want snaps that will rust on the floor. Added a hard to find skinny low profile black tool box as well so I can still fit my bike in the back. And got rid of the  red tow hooks ( I know some people like them but I don’t )
Edited by Dirtbiker
Sent in some custom requests to:
https://www.0fx2gv.com
Made some mock ups, then fab and sent. Super easy.
Not cheap, but they’ve held up well.
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
