The weird thing is that the passenger side has a larger leak then the driver. But the driver side is what has the issue. As for the s1b1 sensor. I have replaced it 2 times and still have the old sensor. Never changed a thing. The low power reference wire is it supposed to be a 5 volt supply? I’m getting 2.9 volts and the other wire is only reading 0.4 volts. It’s the same on all 4 sensors. Also the exhaust leaks is the flange gasket. The manifolds are not leaking. I put anti seize on the bolt that fell out and put it back in.
Edited by casey.mikl
55 minutes ago, davester said:
It can.  I know on my truck, which had 6 broken off bolts when I bought it, the O2 sensors indicated mixture was very lean until I fixed them.
Yeah because the air is going out before it hits the O2 sensor...
I’m going to get a set of o2 wire extensions and connect the passenger sensor to the driver side and swap them. That way I don’t have to remove the sensor. See if my issue changes sides or stays the same.
Having the same problem on 2011 2500 hd 6.0 mine is bank 2 o2 sensors flat line idles rough pops through intake under load then like a flip of the switch it idles fine and runs great.
replaced o2 read voltages checked crank sensor went through wiring harness bla bla bla i decided to clear codes fire it up pull plug on throttle body it idles fine throws no o2 codes at all only code is the tbs code of course  changed throttle body did relearn lasted a day went back to doing the same thing changed for second time no difference  this all started after putting and brand new transmission from gm in it and have tcm flashed
Edited by lnb
more information
My issue started after I had my transmission rebuilt. I have swapped the throttle body off the wife’s Tahoe and it was having the same issues. I have not figured it out yet.
  • 1 month later...
Did you ever resolve the issue I have a 2013 2500 6.0 doing the exact same thing
I really hope someone can figure it out. There is 1 forum post I saw online that the guy replaced all 4 02 with I think Bosch sensors and it fixed his issue. I’ve replaced 02 sensors 3 times already with no fix. The codes it pulls is for up steam bank 1 02.
   Im just getting started on this one. All I have done so far is swap B1 S1 & B2 S1 O2 sensors to see if issue moved to other side. In which it did not. Same as you B1 is rich with missfire cyl 1,3,5&7. Also has recently had converters removed. Have you tried an injector balance test?
I replaced all 8 injectors, map sensor, maf sensor, crank sensor, swapped throttle body, smoke tested intake and exhaust, checked wire harness, new ecu. Nothing has fixed it. Hasn’t even put a dent in fixing it.
Diagnose. Quit throwing parts at it, you are more than likely making it worse.
There is a website you can subscribe to that basically gives you a technician view on how to diagnose the codes. Can't remember the name but that is what I did to fix a similar code.
I have. I have tested the harness. Tested the sensors. Checked and changed grounds. Nothing has fixed it. The codes are 02 sensor codes yet everything has been replaced and is working fine.
Then you are having engine problems not O2 sensor issues. You aren’t getting enough air or fuel somewhere
    • Lauren Fix Is AI quietly deciding what you pay at the gas pump? How the algorithm picks drivers' pockets.   Every time tensions flare somewhere in the world, gasoline prices seem to jump overnight. Drivers expect it. The news blames geopolitics, oil traders blame uncertainty, and politicians blame each other. But here's the question almost nobody is asking: If computers can raise prices within hours, why do they suddenly become so patient when it's time to lower them? Americans have lived with this frustration for decades. The price of crude oil climbs, and gas stations respond almost immediately. Crude oil falls sharply, and suddenly we're told to be patient. Refiners need time. Distributors need time. Retailers need time. Somehow, that urgency only seems to work in one direction. Regulators have already gone after algorithmic pricing in apartment rentals, and they're looking at hotel rooms, airline tickets, and online retail. Now a new California lawsuit and a federal push to investigate gasoline pricing suggest there may be another piece of the story that deserves far more attention. It isn't simply about oil markets anymore. It's about artificial intelligence, algorithms, and whether software designed to maximize profits is quietly changing how fuel prices are set across America.   If that sounds like something out of a science fiction movie, think again. Kalibrating the market? Kalibrate is a real pricing platform. The company markets its software as an advanced pricing solution that analyzes competitor prices, wholesale costs, local demand, traffic patterns, and countless other variables before recommending the "optimal" price at the pump. By the company's own marketing, it serves many of America's largest fuel retailers and convenience store chains. Retailers use it because it promises to increase profit margins while staying competitive. There is nothing inherently illegal about any of this. Every major industry now runs on data analytics. The concern begins when pricing software stops simply reacting to the market and starts shaping it. On June 22, three California drivers filed a federal class-action lawsuit in Sacramento — and they didn't just sue the software company. They sued the gas stations. Kalibrate is the lead defendant, but so are Marathon, BP, Circle K, 7-Eleven, Speedway, Walmart, Sam's Club, and Albertsons. According to the complaint, Marathon alone runs more than 1,000 ARCO stations in California and has been letting Kalibrate set prices at them since 2020. Circle K, plaintiffs claim, has more than 400 stations on the software. Albertsons, they allege, has been using it since at least 2009. The complaint alleges that Kalibrate allowed competing retailers to share competitively sensitive information and receive pricing recommendations that discouraged aggressive competition. It describes a "restoration" feature that plaintiffs say lets nearly all the stations in a market raise prices at the same time. It also quotes Kalibrate's marketing, which according to the complaint tells operators that even in the face of "falling oil prices ... it's critical to avoid a race to the bottom," and warns that cutting your price to win customers "could be making a change that triggers a downward spiral." The plaintiffs call the platform the "central nervous system for a conspiracy to extinguish retail price competition among gas stations." Price pumping What does that cost you? Research cited in the complaint found that stations switching to this kind of software raise prices by about 6 cents a gallon on average — and by as much as 30 cents where most of the stations in an area are running it. Plaintiffs point to a real-world example too: They allege that when one California Albertsons turned Kalibrate on, its pump price climbed 3 to 4 cents within days. That sounds small. It isn't. By the complaint's math, a single penny on the statewide average drains $134 million a year from California drivers' wallets. Kalibrate says it disagrees with the allegations, calls its technology lawful, and intends to defend itself. The retail chains have not yet answered the complaint. No court has ruled on any of it. But what happens when thousands of competing businesses begin relying on the same algorithm to determine prices? Price fixing has been illegal in California for more than a century, and the plaintiffs are suing under that old law. What's new is a statute that took effect on January 1 — AB 325, the Preventing Algorithmic Collusion Act — which says plainly that you cannot escape a price-fixing charge by routing the conspiracy through software. Using pricing software is still perfectly legal, but using it to coordinate with your competitors is not. AB 325 makes it unlawful to use or distribute a "common pricing algorithm" — software that uses competitor data to recommend, align, or stabilize prices — as part of an agreement to restrain trade. Whatever you think of Sacramento, it closed that loophole first, and this case is the first real test of it. The A-word Washington is applying pressure of its own — though it is worth being precise about what kind. On July 3, the Department of Justice and the Federal Trade Commission sent every state attorney general a letter urging them to investigate whether antitrust violations or price gouging are keeping gas prices artificially high. "Recent volatility in crude oil prices does not suspend either the antitrust laws or state consumer protection laws," they wrote, "and it does not authorize companies to manipulate retail prices or collude with their competitors." The letter followed President Trump's complaint, posted to Truth Social on June 23, that falling crude prices weren't reaching drivers. But read that letter closely and you'll notice something. It never mentions algorithms. Not once. The federal government is going after gas prices with the same tools it has always used, while the argument about the software is being made by three drivers and their lawyers in a Sacramento courtroom. Nobody in Washington has said the word yet. And whether any of these investigations turns up illegal conduct remains to be seen. Anyone who has driven for more than a few years knows the pattern. Prices spike within days of a geopolitical event, then drift down at a painfully slow pace. Economists even have a name for it: the "rockets and feathers" effect, and they have studied it for decades. Researchers point to several reasons, including inventory replacement costs, consumer behavior, and local competition. None of those explanations necessarily involve illegal activity.   Dirty work   But artificial intelligence introduces an entirely new variable. Unlike traditional pricing models, today's software can monitor competitors continuously, process enormous amounts of market data instantly, and recommend price changes faster than any human pricing manager ever could. If dozens or even hundreds of competing retailers rely on similar recommendations generated from comparable market data, the practical result may be less price competition — without anyone ever picking up the phone to coordinate prices. That possibility isn't unique to gasoline. Regulators have already gone after algorithmic pricing in apartment rentals, and they're looking at hotel rooms, airline tickets, and online retail. The Justice Department sued RealPage over the software landlords used to set rents and settled the case last November. The concern in every case is the same: that algorithms may accomplish indirectly what competitors have long been prohibited from doing directly. It's worth being precise about what that settlement did and didn't say. RealPage paid no penalty, and the government made no finding that it broke the law. What the DOJ objected to was the use of nonpublic information from competing landlords — not the software itself. Using an algorithm to price your product isn't illegal. Feeding it your competitors' private numbers is where the trouble starts. That distinction is going to decide the gas station case too. Technology moves faster than regulation. Thin margins This debate also exposes another misconception. When Americans get angry about gas prices, they aim that anger at the oil companies. In reality, what you pay at the pump includes crude oil costs, refining expenses, transportation, taxes, distribution, and retail pricing. Gas stations generally operate on thin per-gallon margins — the National Association of Convenience Stores puts the net at roughly a dime a gallon once credit card fees and operating costs come out — while state taxes and regulatory costs can dramatically affect what you pay locally, particularly in a state like California. If gasoline prices are rising because of global supply disruptions, consumers may not like it, but they can understand it. Markets move. Wars affect energy. Hurricanes interrupt refining. But if pricing software is reducing competition by encouraging retailers to move together instead of competing aggressively for customers, consumers deserve answers. Artificial intelligence is quietly becoming the invisible middleman in countless financial decisions Americans make every day — insurance rates, airline tickets, hotel rooms, online prices, and now what you pay every time you pull up to the pump. Most consumers never know an algorithm was involved; they simply assume that's what the market decided. Algorithms don't care whether you're commuting to work, driving your kids to school, or trying to keep your small business afloat. They don't understand household budgets or family vacations. They optimize. That's what they were built to do. The question was never whether artificial intelligence can set prices more efficiently. It's whether we've quietly allowed machines to redefine what competition means. Because if software can determine the price of something as essential as gasoline today, what will it be deciding tomorrow?   https://www.theblaze.com/lifestyle/is-ai-quietly-deciding-what-you-pay-at-the-gas-pump
    • All valid.   But.  How many people really do this?  Its few and far between.  Most just drop it into D and go.
    • Did you do this after the warranty expired? Or still under warranty? I am guessing the warranty would be void.  I am trying to find a happy middle ground on this by perhaps keeping the cat but removing everything else.
    • Thanks for the responses. Having an issue and not getting support is a real thing and can take the shine of any good product.    I had an issue with my iDash recently and Banks went above and beyond to fix it and that makes me want to deal with them on some other future upgrades so it does benefit any company to support the crap out of their products.   I do like the looks or the VSE parts but can be hesitant if there is a weak back end to support it. I have their CCV and catch can sitting in the cart but haven't pulled the trigger yet. Just want to get feedback and this helps.    @AbzDad have you noticed any change in the amount of build up on the manifold sensors with the reroute?
    • IMNTBHO;  the worst thing for the 6L80 is to be lugged down to low engine rpm while in high gear......AKA, to save fuel.   I rarely use D on my '16 with the 6L80 and use M mode to keep engine RPM above 1500 at the speed I'm driving, which is also benefiticial for the tranny because line pressure is kept up because the pump is actually turning a decent speed, and it's not always hunting to drop to the next gear to lower the engine RPM's.   Never above 30mph.............M3, maybe M4 if just driving thru a small NoDak town Never above 40mph............M4 Never above 50-55mph.............M5   This is way better for the tranny and the engine.........especially if AFM is still active.   262K miles on my OEM 6L80 as I type this.
