Weird Sh** my 2020 Does/Has
1 hour ago, GMguy99 said:
I was saying that i do not have the keyless entry buttons on my rear exterior door handles.  My brother has a 2019, and his does.  Looked a few more 20's...they don't either/.
My 2020 Sierra SLT has the buttons on the rear doors.
20 hours ago, loud_pipes said:
I have a 2020 AT4 and can unlock the from the rear door. I do it every day to throw my backpack on the rear floor before getting in the driver’s door (which is already unlocked at that point).
Sent from my iPad using Tapatalk Pro
On my 2019 hard loaded SLT,  I originally had the driver's door handle button set to where it would only unlock the driver's door. Numerous times, I would use the button to unlock the driver's door and open that door and maybe set something on the console, then need to open the still locked driver's side rear door with the driver's door still open. Press the rear handle button...and no unlock. I would have to either unlock on the key fob or manually press the unlock button on the driver's door. That is a tiny little thing, but it just shows another quirk of the system.
On 7/15/2020 at 2:37 PM, GMguy99 said:
Interesting info on the cargo lights. I thought my '04 had them go on at night with the door opening.  I wonder why they don't do that anymore.
Anyway, love the truck, no major complaints just some quirks i'm finding as i spend more time behind the wheel.
I thought most cargo light switches had 3 positions: off, on when door is open and on. Is that not the case with these trucks?
Do you have a 2019/2020? Because I have a 2019. And I, along with others who own the same year models, have noticed the remote start AC running at the same setting it was set to before the truck shut off. You’d think that GM would have it go off of environmental conditions but they DID remove the ability to unlock the truck from the rear doors (present on the 2019 models) from the 2020 models.
In other words: GM is pretty damn dumb when it comes to this stuff.
Mine doesn’t remote start at the last setting. It goes based off of temp outside then when I press the start button when I’m inside the truck it goes to my last setting. 2020
On 7/15/2020 at 12:28 PM, cltsig said:
When I remote start, it cranks the AC and seat cooling until I start it, when it cycles to whatever the last setting was.  There are some settings in the software but not sure it says "full blast or last setting".
Mine will only do last setting. Which stinks mid afternoon. I pull into work and it is cool, so I have the AC fan on the lowest setting. In the afternoon it is 100 degrees outside and when I remote start, the AC is still on low fan speed. ugh!!
On 7/15/2020 at 4:29 PM, ullose272 said:
My truck does not have the rear door handle buttons, i believe it is because of trim levels, mine is an rst where i believe the ltz/denali have the rear door handle buttons
Sent from my SM-G973U using Tapatalk
I have a 2020 LTZ and no rear door handle buttons.
Very disappointing GM would offer and then take out buttons on the LTZ trim. On the Lower Chevy trims i can understand but Truly money greedy move.
    KJEK
    KJEK
  • Who's Online   2 Members, 0 Anonymous, 609 Guests (See full list)
