I have a 2020 3500hd duramax. If I am going down a steep hill in normal mode and I’m not towing, the rpms rev up like they do while in tow mode. The truck slows down and won’t coast like my 2011 gasser. I’m just wondering if this is normal? Thank you
That's the grade brake doing it's thing.
If the exhaust brake is enabled it will assist in this process.
Truck is trying to maintain the speed it thinks you are asking for.
No runaway coasting....
FWIW, max rpm under decel is higher than max rpm when powered
Maximum Powered Speed 3450 rpm
Maximum Braking Speed  4800 rpm
  • 3 months later...
Hello JHarris32.  At your earliest convenience can you PLEASE attach a short video clip of the instrument cluster(rpm guage) while this situation is occurring. Also please note your vehicle's build date, this can be found on the driver's side b-pillar placard. Thank you so much in advance!!
Edited by JRSPerf.
High RPMS?  What are the RPMS at high speeds and flat surface?  Say at 70 and 75 MPH.   MIne runs at about 16/0 at 70 and about 16.5 at 75.  This is of course in 10th gear
I’m curious why you ask. The owners manual for my 2021 gas 3500hd says that transmission grade braking only works in tow haul mode. On mine, grade braking works in normal mode on descents.
Edited by Another JR
My 21 does the same.  If it's a steep enough hill I turn on the trailer mode to make it more aggressive.
Not sure if this is what is going on, but if cruise control is set, it tries to maintain set speed on the downgrades too.
Same thing (downshift/high rpm) can happen with a 1500 gas truck and no trailer -- if the grade is long and steep enough.
With cruise off, it will likely still add grade and/or exhaust braking if you use the brake pedal (which tells it the vehicle is running faster than you want)
HD's, and especially the dmax, are all about load control.
They 'coast' less than a 1/2 ton.
And the 1/2 ton will 'coast' less than the passenger vehicles.
Sounds like the Exhaust Brake is holding your speed. Welcome to a HD truck. If you want to continue to accelerate hit the gas pedal for a bit and I believe it will let you coast, or at least let the truck now you are ok with a gain in speed.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 291 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
