37 minutes ago, slj2008 said:
It doesn't hurt to stop by your your Local PD/Fire/Ems - and ask , they may know someone that does side job's. Good Luck
My cousin & her husband are both EMT’s; might have to ask them.
On 8/3/2020 at 1:31 PM, 2020AT4 said:
I've been piddling around the idea if putting a small CB radio in my truck just for poops & haha's; and nothing other than when we go on road trips with friends and we're in separate vehicles. It'd be better than the group texts we currently do while driving. We've talked about getting little handhelds but it looks like they still have a lot of manual squelch, gain, frequency adjustments, and don't have much for distance; none of us are professional radio operators or truck drivers that deal with that stuff daily. I did find a small CB radio that has automatic squelch controls and stuff all built in and still give normal distance. I wouldn't know where to mount it in my 2020 AT4. It'd be nice to have it hidden as much as possible because I don't want it sticking out like a sore thumb or have cords dangling everywhere. I like things to have that factory look, which is also why all the antenna ideas scare me a bit, drilling into stuff or have an big ole bracket hanging off somewhere that look ugly af. Then I saw this mounting option for an antenna that looks pretty close to factory (see picture) - same looking antenna mount style as the regular AM/FM antenna, just on the driver's side to keep that factory look. In all honesty I'd probably leave the antenna off most of the time and just put it on during those road trips.
Any ideas for a nice hidden mounting option for a CB radio in a 2020 AT4?
Any idea where to find this plastic piece for a driver's side antenna mount for a 2020 AT4, like the one pictured? (No idea the year, make, or model of the truck pictured)
This is what I did in my 2500.  Not sure if you are willing to cut that much though, lol.
As far as small units, the President Bill I used takes the cake.  Unless you want an "all in mic" unit.  Only thing I miss is not having a PA...
I do like the install; looks nice & clean, but it does look like more cutting than I'm prepared to do. I was shooting for the radio hidden more in the flip up part of the center council. I did see that President just came out with a handheld CB with ASC. I might have to give that a whirl first before I consider a more elaborate install.
RANDY FCC- AM-transceivers - CB-Radios - Group President Electronics USA (president-electronics.us)
    jaszr2
    jaszr2
  • Who's Online   5 Members, 0 Anonymous, 460 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
