Has anyone modified or replaced the seats on their truck?
I’ve got a brand new LTZ that is so uncomfortable to sit in that I’m considering taking a massive loss just to get a different truck. Seems it’s the vibrating module in the seat or maybe the platform for something. But it’s unbearable and not drivable for me. Tried calling a couple shops to see if they could make suggestions and pretty much struck out.
Did you not test drive the truck before you bought it? If it's as bad as you say then i'd think it would have been a deal breaker and you would have walked away.
As far as modding the seat,  i'd think you could have an interior shop add some type of padding for way cheaper than taking a huge loss on getting rid of the truck
Yes, of course I test drove it. The problem didn’t start until I put about 50 mins of drive time.
But all that is irrelevant now.
I can’t take much more than 5 mins in the seat and am looking for options. One upholstery shop told me they wouldn’t mess with a brand new seat and isn’t much they would do.
Perhaps, GM can switch out seats for me. I’m willing to pay. It’s better than losing 15k on selling a new truck with 200 miles on it.
seats are pretty uncomfortable.....very very firm, idk if a swap is gonna change much because thats just the way they are
a shop adding foam is best bet, find another shop......someone will do it
Edited by Dunn
Buy a used seat and mess it up saves yours to put back.... try a junkyard...
Just got a 2019 LT with 5400 miles.  Driven it a week.  Drivers seat is unbearable, mostly in the right side.  The pain is relentless. You can actually feel the sensor.  I, too, will take a loss if this can’t be rectified.  If anyone has found a solution, pls let us know.
I bought an Ultimate Purple Cushion that sits on the seat. It works wonders. The Purple Cushion is for people weighing under 200 lbs. The Ultimate Purple Cushion is meant for people 200 + lbs.
Edited by UsaKansas
Had more information to help with.
Is that one breathable? Can you feel the ventilation or heat? What about the vibration, can you feel that you? tried their Everywhere Seat cushion on a recent road trip. It helped in that my leg didn’t go completely numbs, but it was still not comfortable.
I’m working with a Sr Mgr from GM to see if they can come up with a resolution. Swapping my seat, they claim, would void my warranty.
The leather seats in our lt are very comfortable.  Have lower back issues and the 8 hour drive home after buying the truck was not at all uncomfortable.
If I was in your situation and money was not a concern, I might check into a katzkin option.  I am eventually going to do the katzkin leather conversion in our impala to replace the cloth.
Heywalt...... please let us know the outcome.  My dealer is totally perplexed.  Thanks!
My dealer looked at it, felt that it’s the haptic system in the seat and said other ones are just like it. Not a defect with my truck. :/. That’s why I’m back with GM which will likely not yield anything positive other than platitudes. I’ve asked before that they buy back my truck. I’ll ask again. And again. And again.
 Yes it is breathable. I tried many cushions. The Ultimate Purple Cushion is the only cushion that didn't flatten out like a pancake. It still has some spring in it, when sitting on it. Driving a 2500HD with 80 lbs of air in the tires, and hard seats was taking it's toll on my old back, and legs till i got the Ultimate Purple Cushion. If you get one, shop around. I think i gave $60 for mine. They ask a lot more on there sight. Either way, it's cheaper than replacing seats, or buying a different truck.
It just seems odd... i have a 2012 and miss the arm rest in my old 05 lt both have leather but I do like the cooled seats.
    Matt Parker
    Matt Parker
  • Who's Online   3 Members, 0 Anonymous, 878 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
