After some thought and posting this question, could it be that the previous owner installed this borla exhaust and didn't do a updated tuning to the motor/ transmission which is causing this bump from behind feeling at stops?
No.  I assume you have the 8 speed?  If so, its normal.
Quote
16-NA-361: Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle
Some customers may comment that the transmission exhibits a harsh 1-2 shift on the first shift of the day, typically under light throttle.
This condition is due to the initial clutch fill time of the 2-3-4-6-8 (C4) clutch.
Some customers may experience a flare condition on the first 1-2 shift of the day or after the vehicle has been parked for several hours. The condition may have developed after the replacement of a complete transmission assembly or the replacement of the stator support to correct a delayed engagement condition. This is most likely to occur under light throttle conditions. Subsequent 1-2 shifts have acceptable shift feel. Replacing transmission components will not correct the condition.
Important: Replacing transmission components or complete assemblies will not improve the condition.
The first 1-2 shift of the day may be harsh. The customers’ vehicle should be compared to a like vehicle under the same driving conditions. Do Not replace any parts for this condition.
Note: This condition will not impact the designed performance or reliability of the vehicle.
Worth trying, there are a lot of posts on the site here about the subject, lots of reading about cures, and no fixes at all.
