Just ordered a set of JBL concert series for my 2020 LT Trail Boss...Anyone else running these speakers???What is everyone running for there after market door speakers?
I was looking at the GTO series by JBL and was wondering the same thing if anyone was running then
I was looking at those ones also,but it said the rears wouldn’t fit in the doors...I wanted to keep the speakers matching so i went with the concert series..Plus they were on sale,and crutchfield gave me free harnesses,and speaker adapters .I ended up spending 150$ for the 6x9 fronts,both my 6.5 rears,harnesses plug and play for all the speakers,and both adapter kits for 150 with 2 day shipping was a no brainer for me...You running an amp???
Your going to have to run an amp to get the most out of those speakers.  To get out of running an amp, you have to go for lower power speakers.  The radio, even the Bose amp, doesn’t  put out much power.
Similar radio in my wife’s Traverse, used some Pioneers in the doors, no amp.  Huge improvement.  Did Crutchfield for them as well, frees adaptors and wiring harnesses, $50 I think, they were on sale as well.  Took maybe 1.5 hours total.  That’s doing the sound deadening as well.
Got Bose in my 2020 RST, so just gonna add a subwoofer.
Went with JL Audio C2-650s all the way around personally. Just finished the install actually yesterday.
Definitely better than stock but can’t really tell their full potential until they get amped one of these days
I plan on adding an amp,and sub...I reached out to 2 different people who make the harnesses for our trucks so it's a plug and play for the amp...One place said they're closed until september,and the LLj place has yet to respond...
Yeah, I’ve seen a lot of people comment on some other threads that’s the issue with LLJ.
Are you doing anything with the dash speakers?  I know Sundown audio makes a drop in speaker that sounds really good.  Probably one of the best sounding 2.75 speakers I’ve heard.
I was looking into those,but couldn't find anything on crutchfield...Thanks for the heads up on the sundown ones...I'm going to look into them...
I installed Alpine S series 6"x9" and 6.5" on my non-Bose LTZ this past week.  Huge improvement over stock as far as clarity, mild improvement in bass.  Well worth the upgrade for $147 all in, I was able to score some open box items through Crutchfield, and it came with everything for a easy install.  I have a sub and amp ready to be installed, but I'm trying to figure out a mounting solution I like first.
For comparison it would have cost me an additional $1000 to get the Convenience 2 package with Bose, Nav, and the wireless charging pad.  I really hated the wireless charger since it takes up the whole front storage, and I use apple carplay everyday for charging and Nav, so it would have been pointless.
Edited by pewterliftedz
So I installed my JBL concert series speakers...The total install took about 1&1/2 hrs with sprakers brackets and plug a d play harnesses...They sound literally a 100x better than the stock crap without an amp....I have the 8" IOR radio non bose and these speakers made a huge difference in sound...In the speakers with everything for 150$ and was here in 2 days...I highly recommend the Bose Concert series on Crutchfield...They're on sale right now too..
How’s the bass and clarity at high volumes without an amp?
These are the ones I installed. A lot of mids and highs but no lows. Fortunately it’s what I was looking for since I have the factory 10” kicker sub in the back.
I have the kicker system for the 14-18 double cab that amps your speakers as well as the sub. Sounds amazing and the added power really brings even the factory speakers to life. Was $1250 new, just trying to get rid of it since I sold the truck - let me know if any of y'all are interested!
Do you have the model numbers you used. I checked crutchfield and they said they do not fit.  Thank you in advance.
For the JBL speakers???
    TopBo
    TopBo
  • Who's Online   1 Member, 0 Anonymous, 693 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
