My truck is an ‘18 Sierra crew with the 5.3. Just started noticing this vibration that feels like driving over small rumble strips. It comes and goes for a few seconds while I’m maintaining around 55-60mph. As soon as I give it a little gas it goes away. You can feel the vibration in the steering wheel. I’m thinking it’s a transmission issue, or maybe bearings?  I’ve got around 55,000 miles on it. Thoughts?
In the same boat still. Have had numerous road force balances done. Have swapped tires out just to rid a variable. I believe mine is the converter but cannot get any dealer to feel what I feel. They check everything out and say its good. Mine happens from 68 thru 75. Some days its more noticeable than others. Also have had shaft checked for balance, all good.
Sent from my SM-N975U using Tapatalk
My neighbor has a 17 and says he has the same thing. He paid for some magical flush and it helped but they said if it comes back, that he'll need a transmission.
Sent from my SM-G892A using Tapatalk
Thats what I'm afraid of hearing from the dealer when they decide something Is wrong. I've read from quite a few people that they have flushed and threw in amsoil with great success. But I'd really like a tech to see this first before I start changing up on fluid.
Well, hopefully if it does come to that your power train warranty will cover it. Mine paid for a 4k AFM Lifter job about 10k miles ago.
My transmission worries me a bit, too. I've noticed that if I get on it from a stop I sometimes get at least a full second of slip on the 1-2 shift. I'm worried it's gonna give up the ghost one day while towing my camper.
Good luck. I hope the warranty covers you if the tranny is bad.
In the back of my mind hovers the dod system and the potential failure of it. But for now it seems fine. I baby it to keep it outta 6th gear if I can as to not engage 4 cyl mode. But on state to state trips in the 80 mph zones that 6th gear really helps.
I'll just keep pushing the dealers around here and hopefully one day they'll break and take me seriously about the converter.
My warranty is good to 60,000 miles, and I’m at 55. I’m looking into the cost of an extended warranty. What’s a new transmission cost installed at the dealer?
I'm not sure about labor costs, but you can get a reman 6l80 for about $2500. But i have seen from Monster Transmission a built up one for around $5500. Somewhere around that price anyways. I would suggest if you are thinking about a new trans, if budget allows, get a built up one and never have to worry about it again. If I run into this down the road I will probably go this route.
They told my neighbor it'd be about 4k for his 8-spd. You sure your power train warranty is only 60k? It's not the same as the bumper to bumper... Mine is good to 100k and I'm at about 86.
  • 2 months later...
Geezz, mine is doing this now (rumble strips/braille driving) and it thought it was the road pavement. I'm a 17' with only 19K mileage.
2016 Sierra 6.2.  At 30K miles I would have a periodic shudder (like rumble strips).  Got the TSB, took it to my dealer,.  The TSB calls to change out the Dextrose tranny fluid with special Blue Mobil 1 fluid.  It works...no more shudder and-last week,  I pulled a 6500 lb travel trailer in the mountains, with no reoccurrence of the shudder.  May consider changing out the tranny fluid every 30K miles given I pull a travel trailer.
Same issue with mine. Did the flush 60k ago. No problems since. Best $200.00 spent on this truck.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
