My MX4 came with the larger rubber blocks and separate instructions to install on 2019/2020 GMC/Chevy. With the rubber blocks, it rests on the back window.
Mine came with those larger blocks also. But even if I push on the cover towards the cab they won't touch.
Sent from my Pixel 3a using Tapatalk
That rear view camera mirror is awesome. That's definitely one option I wish my SLE had.
Mine did not come with the blocks. I put the smaller ones on. I’ll contact manufacturer and see if they can send me some.
As for the rear view mirror, the visibility is amazing going dow the road. I can see everything. It really helps when I have the kids in the back with all their stuff blocking the window or things in the bed of the truck.
17 hours ago, cNate said:
If you force it to the cab and then crank down the holders, it’ll stay against the cab. It also won’t obstruct the view of the review and bed view camera. I specifically choose this cover for that reason. Moving from a bumper pull to a fifth wheel and wanted to be able to have the cover out of the way and hitch up. It’s also convenient when filling the bed with stuff to have almost full access to the entire bed space. My old truck and cover took up half a foot or so of bed space fully folded up, which only mattered when I had bikes in the back. That half foot meant I couldn’t close the tailgate. Not an issue on the longer standard bed of this gen truck though and this style cover.
Yeah, that's what I do if I want to fold it completely. On another note, as easy as it is to remove, you can also take the whole thing off in a few seconds. This is my third BakFlip, second for this truck, and overall they are pretty good. Customer service is as well. I had an issue with the first one for this truck and they had me do some things and ended up warrantying it and shipping me another. No problems with this one. Currently, I took mine off so the dealer can work on the leaking rear window and it won't be in the way or them try to stand on it for prolonged periods. Kind of odd seeing the whole bed all the time again!
On 8/13/2020 at 12:38 PM, Alan Juden said:
I'd be interested to see what the bed view camera and the rear view mirror look like from inside when you have the MX4 up like that. That's the bed cover I'm looking to get as well and haven't found any pics of the cover up like that. Any chance you'd be willing to either let me know whether or not those cameras are blocked or post a couple pics of the camera views with that up?
I dont have a pic from inside the cab, but it doesnt block my cameras at all if i push it forward and lock the bars in place. 20190809_200533.thumb.jpg.95052e39d48353c9f6b7b1b2edb3ec7f.jpg
Did you ever find a solution? I am having the same issue with it being about 4” away from the cab
Edited by Arkangel
I cant tell by your pictures if this is your issue but in order to get it to go all the way forward you have to make sure its "compressed" at the base. If I just fold it, the last fold leaves a gap between section at the base. I have to hold it vertical and  hold the base/bed end/bottom together to get it to lay all the way forward.
I'll try to get some pics in a bit.
If you look at the lower part of the fold you can see one has a larger gap than the other. The larger gap is as result of not "pinching" the bottom together during the last fold.  Hopefully this helps.
Edited by sdelam
Inside views with cover in the up position. This is with minor pressure on support struts, I can push it farther to see the bed better if needed.
Yes I tried every which way,
Spoke to Bakflip this morning the sent me a video on how to fold to get it to to touch
Tried it and it was 2x as bad
Sent them a vid of their “fix” and now they want all my info to warranty it.
I had mine replaced under warranty for a different issue and they both fit the exact same and neither touched the cab like some of the earlier posters here showed.  I honestly don't think theres a "problem" here. If I apply a small amount of pressure it will touch the cab and then I can lock it in with the arms.
I'm afraid if you end up with a replacement, you're not gonna be happy with the one either.
Did you have to send your original one back to them? I havent tossed the box yet in case I do.
I have to apply more than a small amount of pressure to overcome the gap, when I tried it resulted in stress on the panel closest to the cab, the rubber joint, and the mounting plate attached to the rails and hardware
I think this will eventually lead to premature failure at one of those points. If it was designed to function this way Bakflip would have said so, but they are acknowledging the fact that it is not functioning as intended which is why they are warrantying it.
I have not been able to find any information on a Bakflip that does not touch the cab when folded from any other truck including Ford/Dodge/Toyota etc. If the next one doesn't solve the problem then I think Ill be going with a different cover.
    • This is just a thought as I can't claim this is the correct thing to do but will suggest it and you can decide if its something you would try. First round up some electrical contact cleaner spray as they at least claim its not supposed to damage the components ( brake cleaner depending on the type is a real destroyer of plastic etc ) and to use that to assist to clean out any grime from the pins as well as the mechanism by spraying and working the lever etc. Then my next thought is to use silicone spray lube and not on the pins but on the seal and the pivot assembly. It may not be possible to spray it on certain area's and have to use a q tip as Davestar mentioned to keep it from getting on the pins. Dielectric grease can be fine on some things but its easy to get too much on if not careful and then gunk things up and a possible risk of getting it on the pins or sockets. The silicone spray is able to get into a mechanical component to help lube and on surfaces its just a fine film to reduce friction such as that seal. Also it can be doused off with a good flush of the electrical contact cleaner the next time for a repeat of a "clean and then lightly lube" step process to wash off any dirt that had stuck to the exterior etc of the plug.   Free advice, yes. Good advice ... now there's the question mark !
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
