3 hours ago, Arkangel said:
Did you have to send your original one back to them? I havent tossed the box yet in case I do.
I have to apply more than a small amount of pressure to overcome the gap, when I tried it resulted in stress on the panel closest to the cab, the rubber joint, and the mounting plate attached to the rails and hardware
I think this will eventually lead to premature failure at one of those points. If it was designed to function this way Bakflip would have said so, but they are acknowledging the fact that it is not functioning as intended which is why they are warrantying it.
I have not been able to find any information on a Bakflip that does not touch the cab when folded from any other truck including Ford/Dodge/Toyota etc. If the next one doesn't solve the problem then I think Ill be going with a different cover.
No, they told me to throw it away, so thats what I did.
I'm not sure I would want it to touch the cab as long as the camera is clear. I've made a 12 hour drive with the cover folded up without any issues. The arms kept it locked in place without rubbing the cab which is fine with me. As mentioned, I can make it touch, but I'm just not sure why I would want to.
To each his own I guess, this is my 3rd Bakflip, the others rested on the cab without having to apply a single ounce of pressure. A bunch of guys have them at work and theirs all touch, thats what they were designed to do, I think if it doesn't and it just bounces around on the “living hinge” something is going to fail prematurely.
If it wasnt a problem I dont think Bakflip would be replacing it before I could even ask for a replacement ??‍♂️
I’ll update when I get the new one.
Mine was missing a seal and piece of foam and it leaked like a sieve. I called them and had to send pictures, etc to them. The rep was very understanding and helpful. Once I sent pictures of my cover after I beat it with a ball peen hammer, they sent me an entire new assembly. The new cover has been great, and no, it doesn't rest completely on the cab, regardless of how far up I adjust the rails or cover, but it works well. I can force it onto the cab and lock down the bars, but normally I just fold it 3 times and use the strap when towing the 5th wheel.
Thanks for the update!
I’m picking up an AT4HD next week and looking at the MX4. Are you saying you don’t have to fold the cover all the way upright when pulling your 5th wheel? If so, that’s great to hear as I was wondering about that.
Correct. I just fold the 3 rear panels onto the 4th (front) panel and strap it in place and go. It works great and you still have a little bit of covered area in the bed if you need it.
You have the standard size bed? Just want to make sure since the MX4 cover has 3 panels so folding it twice would give 2/3 of the bed space.
MX4 has 4 panels for the standard HD bed
Edited by Arkangel
Yes. I have the standard 6’9” bed. The MX4 I have has 4 full panels and a stationary, smaller panel at the bulkhead. The way I usually run it when towing, gives me about 75% open bed space.
Thank you for the sending the picture. I wasn’t aware the HD standard bed has 4 panels.
Thank you for clarifying that. Appreciate it
Thought Id post this if anyone is interested
Here is a video of the added stress on the rail and mounting bracket when you force the cover to the cab. You can see it pulling the bracket up and causing rotational force on the rail.
The more I do it in the video the less it seems to flex, not sure if related  but after 2 days of rain and a wash this morning, this cover seems to leak more than the last one I had on my 1500
https://imgur.com/a/pagUL9E
Edited by Arkangel
Is that with your warranty replacement cover or the original?
Original, replacement hasn't shipped yet.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
