Anyone find an accessory part solution for a suitable fitting cap for the 2020 Silverado capless fill opening.
It seems to me that dirt particles and moisture, however minimized could effect the vehicle performance & long term maintenance.
thanks
thanks
Not an issue.  There's another door behind the fill door.  The first door is the gas cap but when you insert the nozzle it opens another door.   That's why you need the special funnel to put gas from a can.
thanks
Since the flap is spring loaded with a seal, I can't imagine contamination being a huge issue. Plus there is a door over the full cap as well.
I have seen other posts about a locking cap replacement, but honestly, I love the fuel-through cap. 60k on a Suburban woth it and no issues.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
