So my 2016 WT had the hard plastic steering wheel. It was getting pretty worn out after 162,000 miles. Also the cruise control buttons were wearing off and the rubber was always sticky. So I sourced a leather wrapped wheel off eBay and swapped it into the truck.
Since I wasn't upgrading the cluster and the radio, I decided to swap the blank from my WT wheel to the new leather wrapped wheel for the DIC control pad on the right side. Also the new leather wrap wheel has the volume/seek buttons on the back, but they do not work. I would have to upgrade the cluster, and the radio module to get those. I wasn't really looking for that, just the upgraded leather wrapped wheel, since it's much more comfortable in the hand while driving.
Made a video on how to do it all. Check it out below! Thanks for watching.
Always enjoy watching your videos.  Great work as always!
Hey Phil. Likewise! We should figure out a collaboration video we can do someday. I’ll send you a PM.
Thanks for posting.
4 hours ago, Chev-mekanik said:
Maybe there is a market for my leather non heated steering wheel!
Absolutely. Post that thing up on eBay. I bought the one in my video for around $100 + 15 shipping.
Granted, Not many people will spend money to swap out a work truck wheel, but my company says treat your work vehicle like your own, so I take some liberties on creature comforts and such.
  • 2 months later...
Definitely.  I'm hunting for a black leather wrapped.  It looks like they are $159 at GM Parts Direct for just the wheel. I'm assuming that all the plastic bits will transfer over from a WT Wheel to a Leather wrapped wheel?
crap same here! I have a Silverado and a Sierra steering wheels sitting in a box in the basement from my swapping them out.
i was hoping someone would attempt a Camaro or Colorado wheel swap, i like the smaller wheels myself, for quicker turning and more knee/leg room while driving
I have a non heated black leather with red stitch wheel in the garage as well.  Anyone want it?  Came off me old 15 Sierra SLT All Terrain.  ( I miss that truck, damn drunks!). I swapped to a heated wheel before it was totalled, so this one is perfectly fine.
Anyone done the swap on a work truck and tried getting the steering wheel controls to work with an aftermarket radio? I know you need a cluster and a different radio/flash to make it work on a stock, but I'm wondering if enough wiring is there to make it work with the aftermarket adapter.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,412 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
