I have a Brownstone Metallic 2015 Silverado built at the Flint plant in May 2015. The truck has 52,000 miles and has been sometimes driven on gravel roads.  I must have got lucky, my paint looks like new everywhere, not even one rock chip. I have never had a vehicle with a better paint job.
Dave
On 9/9/2020 at 10:08 AM, DeltaTek said:
I’m also having the same issue in the same spot, having the dealer look at it today, if they say no then there should be a class action lawsuit against the company for defective paint. Just saying.
Let me know what the dealership says.
Same year, same colour, same luck. but Sierra built in Mexico.  It is strange why some peel and flake while most don't. Maybe the cause is a result of factors after the vehicle was built.
  • 7 months later...
I have a 14 Sierra that’s the same color as yours and the paint is flaking off in the same spot on both rear doors.
I have a '14 Sierra and it is doing the same of both doors, the hood from rock chips, and the bed of the truck is peeling like crazy.
It is Metallic Silver. I recommend anyone looking at buying a used '14 Sierra RUN as fast a possible because the paint job of these trucks is horrible.
I have tried to mitigate this the best I can with touch up paint and covering the affected areas to prevent it from spreading but it is only a matter of time before that happens.
I love the truck and mechanically the truck is sound but I am severely disappointed in the GMC paint job.
When you try and fix it use the GMC Paint Touch Up. Do NOT use Touch Up Direct as it will ruin the paint and not match. I used TouchUpDirect and then went on top of it with the GMC paint and it looks horrible. It made the paint "wrinkle" up. Here are some pics and maybe you can learn from my mistakes.
I have a 2014 Summit White that is peeling as well. Same spot on both rear doors and dead center of the cab about 2 inches back from the windshield. Several small places on the front end but I have not ruled out rock chips for these.
Yep, 14 Blue Topaz metallic, Drivers side rear door, same place, starts at the bottom of the window and goes up about 3 inches and a inch wide. I'd say manufacturing/Paint shop problem.
Anyone else having issues with the paint peeling off your truck?  My 2014 has started to peel and when I contacted GMC they said it was my problem and refused to help fix it.  The dealership wants $1700 to paint the entire door.  I haven't even owned the truck four years.  Any advice would be greatly appreciated.
I have a 2014 Sierra that has this same problem, same spot. I called and was told they couldn’t do anything about it.
Apparently, their is an issue with this model in that area of the vehicle. I am totally disappointed as I purchased new and paid extra 1,000 for this color.
Exactly the same thing happening to me.  Drivers side door- same spot.  Not sure what I'm gonna do.
Dealership told me it wasn’t their fault and told me to go to their service department to get an estimate. Painter at the service department told me it’s an e-coat issue that doesn’t allow the paint to bond correctly.
Same issue on my door. Now seeing it on the hood and around the front windshield.
    doylej24
    doylej24
  • Who's Online   2 Members, 0 Anonymous, 664 Guests (See full list)
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
