I recently purchased a 2020 Chevy Silverado 1500 Custom 5.3L. At about 3,000 Miles I noticed the steering would pull to the right just slightly to where I have to slant the steering wheel to the left slightly. At first it was very odd to me because it's such a new truck and I'm already having alignment issues. As I asked around to others with the similar year,make,model a couple of them had the same issue around they same mileage. I'm curious to know if it's just out of luck or if others are experiencing this same issue.
Air pressure correct in all tires?
Did you hit any bumps/pot holes?  I did that with my previous truck (Ram) when it fairly new and instantly needed an alignment.
Pot holes! I hit one not to long ago and threw my alignment off just enough that I had have it re-aligned as well. Happened about 10000 miles. First for me since my previous trucks took potholes like a champ and only needed to be re-aligned after suspension mods.
Edited by dram1983361
Possible a problem with one of the ABS sensors that is causing the brake to be applied. Dealer should be able to check this out without much difficulty.
