I have a 2011 Sierra SL with a 4.8L.  Battery age is unknown as it was there when I bought the truck.  Over the weekend we were moving our kid into their dorm and I sat out front with hazards on and nothing else.  When I went to leave battery didn't have enough umph to start they truck.  Jumped it and started right up and was fine stopping a couple times on the way home.
I let the truck sit overnight and then checked the battery.  It read 13.3V and then 15.5V after starting the truck.  No problems since.
Was this a fluke or is the battery giving a warning shot before winter?  I will probably just replace the battery before winter, but just wanted to know if I am missing something.
Thanks!
I would go ahead and replace the battery.  However, most any Autozone, O'Reilly's or Advance Auto Parts will test it for free.
Most use a high end conductivity tester to check the battery, and the couple of times I've had one tested while still installed, the battery tester showed that the battery in question was in the final quarter of it's life.  It would have been interesting to have been able to get the battery load tested, but none of the stores I stopped by had one for in car testing.
  • Thanks 1
Being stranded is no fun! Sounds like the battery is on its way out but maybe it will last a bit longer? I highly recommend the duracell platinum agm batteries that can be found at batteries plus bulbs, 48 month free replacement. Excellent performance in all temps. Is it reading 15.5 volts with all accessories on? did you test off the post of battery or both that and alternator? make sure you don’t have a loose ground etc. 15.5 seems high and could be bad cell/failing battery. Before you throw in a new battery make sure your alternator is functioning correctly as to not burn it up!
Edited by 04z71crew
typo
  • Thanks 1
Thanks!
https://www.tahoeyukonforum.com/threads/extending-battery-life.117296/
  • Thanks 1
The Duracell is on my short list for sure.  The 15.5 was with only the radio on.  I thought that seemed a little high.
I think I will listen to chem_man and see if I can get it tested, just to make sure.  Just don't want to go into winter unsure.
Thanks!
It's a board error on the older trucks, most prevalent after a driving rain.I'm on my third battery in 20 years, an A/C Delco from Auto Zone, $89 bucks on my dealer account, they stash them behind the counter. Battery light kept coming on, performed a starting/cranking/charging test, all okay. Hey, we gotta keep 'em going.
Our trucks have a smart charging system, look up RVC (Regulated Voltage Control) and EPM (Electric Power Management), that's why your voltage moves around.  A bi-directional scan tool can look at BCM information, like how the charging system keeps tabs on the battery, State of Charge, Start Up State of Charge, Battery Temperature, etc.
My cheap 30 month battery is now 4 years old and has been in Florida almost all of that time, very rare indeed for this climate.
Very interesting. I was not aware of that. The local GMC stealer is very easy to deal with. I think I’ll stop by and have them hook it up. Thanks for the info. ?
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 973 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
