In a dual exhaust set up... what is the purpose of the "x pipe"?  What does it do?
Allows both banks to use both mufflers. Lowers overall back pressure.
Most useful near red line at WOT.
There is an acoustic component as well.
I come from both worlds. Back when 21/4inch duals was a big upgrade from stock. I prefer twin exhaust no cross over for sound. Nothing beats the sound and rumble of unequal exhaust. Not many people have experience twin 2 1/4 glass pack exhaust. The rumble is unequaled at cruising speed.
In a nutshell, an X-pipe or H-pipe evens out the exhaust pulses from the respective cylinder banks, lowers the back pressure a little, but the main benefit is acoustic as Grumpy alluded to, it will eliminate the annoying pulsating drone at highway speeds in a true dual setup and no need for separate resonators.
Personally I LOVED that pulsating drone. Two banks talking to each other. Motor on song. Dad, when I was very young, installed Thrush duels on a 239 flatty. Music to my ears. ?
Ok for short trips or for cruising the blvd. but for long trips, not so much.  I used to have glass packs with no equalizing pipe on my 71 Chevelle SS, sounded great at lower speeds, especially  when de-accelerating in 2nd or 3rd with the M20 4 speed. But it got old in short order. I ended up with a dual setup with an inverted H-pipe and Walker Dyno-Max turbo mufflers, still has a little drone @ 2000 rpm but it goes away at freeway speeds. In 2005 I drove this Chevelle cross-country from Wenatchee, Wa. to the low country of SC where I now reside. 80 mph on I-80 for hours on end and I was turning 3500 rpm with the 3.31 geared 12 bolt. The rusty cast iron manifolds even blued for awhile. But it was whisper quiet in the cabin, I'm sure a drive-by recording may have been different. Pretty certain I would have lost my frigging mind if I would have had to listen to a pulsating drone for 40+hours on that cross-country trip.
I had them on dozens cars and trucks some diesels of various HP with and without headers. All from the same exhaust guy I used for 40 years. Yes the X or cross over scavenges the exhaust better and adds HP. I had that done to scores of vehicles too. It also drones because it equalized. Non equal exhaust rumbles loud or not depending on mufflers. I used them all. Glass packs, thrush, hush thrush, one chambered etc.Even mufflers with removable disks. Even used flange exhaust that exist before the back tires running with a y off full exhaust unmuffled for the drag strip. I know it probably a matter of taste. I like unequal better. I bet most people haven’t heard it. Scavenging the exhaust is the rage now. Large single exhaust does the same on all but very high HP as far as flow.
