Yes I saw that when I ordered mine for pickup.  I guess now that I successfully installed it I am a "professional".    They should just post the link to the You Tube video instead of scaring people.
1 hour ago, Dick Lichon said:
There is a design issue on these vehicles with the amount of stress the negative battery cable places on the post. I got 4 years out of the original and replaced with a AGM just over 1 year ago. Again same negative battery post failure. The bending moment on the post induced by the negative cable fatigue cracks the post inside the battery. The plastic housing holds everything together and you will pull your hair out when temps and moisture cause the air gap in the cracked post to create resistance build up losing voltage and amp draw. Both times mine exhibited starting issues given the amount of amps you need to turn the motor over. Easy way to tell if your post has failed internally is to put a 10mm socket and wrench on the nut of the negative cable and tighten the nut only placing a small amount of torque on the post while someone is trying to start the engine. The post will generally fail on the right side and propagate toward the driver side given the bending moment of the unsupported cable length. There is a hole in the trough above the cable that I used to use a zip tie to support the cable and reduce the stress on the post. You guys may want to do that first chance you get. Hope this helps those experiencing electrical issues that tend to come and go until it finally cracks far enough to put you dead in the water. Regards!
Can you post a picture of the cable & zip tie?
23 minutes ago, 15 Z71 said:
I bought my battery at Advanced and they told me it comes up on their computer that they are not allowed to replace them. Guy told me it requires "professional" to install it on these trucks. Lol
Yep, actually got them to reimburse me for the part behind that.  I think it’s a certain order you have to take the distribution block off or something.
2 minutes ago, Dick Lichon said:
Thanks. May try that although I haven't had the issue you mentioned that I'm aware of. Looks like you have some extra grounds.
I was running a dual battery setup until I installed my supercharger. Took the battery out to install the low temp coolant tank and pump which mounts in the 2nd battery tray. This battery was my spare given the other battery had the failed post. I had a similar side post failure on one of my batteries many years ago. It took forever to root cause the issue. The added cabling doesn't stress the post. It is the main ground in this example. It could be that the factory cable is on the short side to start with. I'm a Mechanical Engineer that worked in auto for many years, I cuss those engineers all the time, ha. Just wanted to point out a potential failure mode for all of you and one that I've seen twice now. I'm going to further support the cable a few more inches before it heads through the amp meter.
I do not have those extra wires on my  truck, just the stock ground wire.  I cannot identify how the ground wire would move separately from the battery.  What do you have the ground wire tied to with the Zip tie besides your extra wires that must be grounding some accessory.  Would zip tying it to the black enclosed bundle behind where you have it now insure the ground wire stays in place with respect to the battery?
It's mostly an inertial mass problem. The amount of unsupported cable is quite long before the cable is constrained. When your vehicle sees accelerations (aka vibrations through normal driving) it places small cyclic bending moments on the post. These bending moments are primarily what would cause the post to fail over time. Basically, high cycle, low load material fatigue failure. I've studied failure mechanics and it is surprising how small loads can be, but if the number of loading events is very high it will induce material failure (aka plastic deformation of the base material). Classic high cycle failure mechanics at play here. Not all will see this issue given there are many variables at play. Material of the post, it's strength, the actual average loading on the cable post, etc.
Edited by Dick Lichon
There is a hole in the metal trough where that zip tie is located. I looped it through the hole to take some stress off the post from the factory ground wire.
The good news is I got a brand new replacement from my auto parts store with another 3yr warranty and a new starter, cause I discounted the failure mode before assuming it was my starter going. I told myself there was no way it was my one year old battery. But, as stated, it was.  I have 105k on the truck. Now I shouldn't have to worry about the starter for the remainder of the life of this truck, hopefully!!
Also thinking about placing a wedge right at the post against the battery housing. This will achieve similar results to lowering the loading at the post.
man I just had to replace my battery on mine.  In AZ I get right around 2yrs typically, just got that Die Hard platinum.
That was the biggest pain in the ass battery to get out, I thought my CTS V was a pain.  Had to take so much ****** off and having the truck lifted doesn't help.  I almost took the reservoir off, finally figured out how to get that ****** outta there.
Quick question, I'm curious, can our trucks not be boosted from another vehicle or use a lithium jump starter if the battery dies?
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
