I searched all over the inter web and couldn’t find the answer. There’s stuff about different rear view mirrors and such but not this mirror (2020 LT Trail Boss).
Has anyone here discovered which wire has 12v power in the basic GM rear view mirror?  I took a photo of exactly what I’m looking at.
Edited by EricTheRed
Here’s a better photo. I’ve searched other GM forums (different makes, models and years). None of them have a 6-pin connector like my Trail Boss. Plus the funny thing is every diagram out there says the ground is black. The closest one I have is black/blue.
Any guesses on these wires which one is 12v ignition?
Try  gen5diy.com . They offer lots of options . I used their escort wire that goes in the mirror housing on 2020 AT4 . Works , but gave me codes (easily cleared) while fooling with it . Daily use now for over 10,000 miles , no codes (yet). Sorta spendy , But what the hey .
  • Thanks 1
Thanks but I’ve got a mirror tap already and just need to make sense of the weird wire colours.
This guy tapped in with his Dashcam and radar detector. I see you’re looking for the basic and this shows a loaded Denali, so I’m not sure this will help
Edited by DarkSky20
Added info
  • Thanks 1
I saw that video and he tapped into a different plug that my truck doesn’t have. The wire colours don’t even match his either. I also don’t have the tools he’s got. So much for winging it haha!
I have a power magic pro I yanked out of a car I sold. I’m afraid to mess with the fuse box I don’t want to blow anything, the car I had was a Ford Mustang and it was super easy to install the fuse tap in that car, mostly because I found a step by step and which fuse to tap in was very clearly explained. I have a BlackVue battery in the glove box for now. I have the BlackVue dr900s Dashcam
  • Thanks 1
There's no 12V power in that connector, you have a basic mirror, that connector is for the windshield temp and interior humidity sensor, leave it alone :)
  • Thanks 1
I think the other plug is tucked away in your headliner since your have the basic mirror. I read that the trucks are prewired for the other mirrors from factory.
  • Thanks 1
That would be great... is it right by the onstar buttons?
There's definitely a plug on my 20 sierra elevation. I have the same mirror as you. I removed the onstar/garage door panel and there's a plug glued to the liner. That might be it.
  • Thanks 1
There's definitely a plug on my 20 sierra elevation. I have the same mirror as you. I removed the onstar/garage door panel and there's a plug glued to the liner. That might be it. This is how you remove it.
Silverado Roof Console Removal .docx
  • Thanks 1
Thanks a lot! I took the roof console out and found the plug glued to the headliner just like you said. They used way too much glue on mine, but it came out after a little bit of patience and a lot of prying. The plug and wires matched 100% with the ones in the YouTube video with the Denali from Dmitry’s Garage. Gen5 doesn’t seem to be aware of the unused plug glued into the headliner. For our application they’re running wires from the passenger side fuse box instead.
Here are some pics of my install if it helps anyone else with the manual rear view mirror. I zip tied the pins too so they don’t move.
Added photos
What cables did you tap into? Going to hook mine up next weekend.
Which color wire of the hidden harness was the 12v?  I want to hook up a map light to it.  I do not have the power mirror like you do, so I could tap into that.
    C. Hart
    C. Hart
  • Who's Online   3 Members, 0 Anonymous, 518 Guests (See full list)
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
