Use this video to see a close up and description of exactly what wires to use for power and ground.
Edited by EricTheRed
The plug that the guy taps into on his Denali is the exact same plug that was glued inside the headliner of my LT Trail Boss (remove the roof console and it’s right there - circled in the photo below). I followed his instructions and used the purple/white wire for power and the black/white wire for ground.
Awesome info!!!    Did you splice into the wires or did you just cut the two needed wires from the plug and use them?
I'm assuming since the plug is "dead" you really don't need it?    Or are the wires completing some type of circuit?
I'm only mounting a map light, but I do plan on using an in-line fuse.
The unused plug had ignition power already running to it even though it wasn’t in play. I used this little wiring harness from Invisicord that just uses pins to slide into the plugs. Pay attention to the type of USB plug you need for your device (I chose mini USB) and the harness pin size (I chose micro pins). The little black box converts the 12v power down to 5v for the dash cam.
http://invisicord.com/osc2/catalog/product_info.php?products_id=58&osCsid=6e06476ee0000188b61c3e0cc10878dd
I finally got around to taking out the the console and found the harness.  What would your guess on the Guage of wire it is?  22?  24?
I'm thinking of using a T- tap connector ....think this will work?
I'm only wiring up a dome/map light and the wiring on that is definitely 20 ga or smaller.
I'm surprised gen5diy wasn't helpful.  Did you contact them directly or just search their site?
And their site has come a long way since I was there last.  He started with making stuff for the 5th Gen Camaro (hence the website name).  He used to hang out at Camaro5 and was always helpful with providing wiring harness info and GM part numbers.
Edited by Jim E
But if you have a dash cam with parking mode this won’t work. Fuse tap is the best route for that. You need a source with power when ignition is off. Like the garage remote for example. I use a power magic pro so when I’m parked in my garage it’s off. When I head out somewhere, I can flip it on and it stays on when I park somewhere and hopefully catch an incident should one happen.
I'm using it for a dome/map light overhead in my cab.  I only need it powered when the accessories are on.
I’m not sure what gauge the wires are, but the T-tap connector should work if you undo some of the tape to loosen the wires.
This is my result!!!   Worked perfectly.  I wrote a post so its searchable in one place.
Great work!
  • 2 months later...
I would like to thank everyone in this thread! I was able to install a dash cam in my 2021 LT Trail Boss seamlessly. I'm usually intimidated by things like that, but all the info here really help.
For anyone with a 21 the wire harness was tucked up in the headliner as described here. The wires matched the video shown here by location and color as well.
  • 7 months later...
2020 Silverado TrailBoss LT
Thanks for all the info! I was able to install this pretty quickly and easily. I didn't take pictures of the wiring because there are plenty here already.
I used HitCar's DC 12V to 5V Power Inverter Micro USB Right Angle (EA-HW02_MOR) for the wiring. It took 3 weeks to be delivered. I trimmed off all but ~6" of the hardwire end.
Once I located the unused connector, I cut back the tape to expose more of the wires. Then, I cut and stripped 1/4" of the the black with white stripe and purple with white stripe wires. Using 18-22 gauge boot connectors, I spliced red to purple and black to black.
The only modification I made to the truck was to the mirror shroud. I used wire cutters to trim away a piece of the vent to allow the wire to float. It had sharp edges after trimming it, so I used a file to knock them down.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
