Good job! I didn't realize the Custom TB didn't come with fog lamps. How did you hook them up?
I was actually hoping they were rear/reverse lights since I can't see worth crap at night when backing up my Trail Boss. I don't like to depend on just the reverse camera either. I've been debating getting the Rigid Industries, https://www.rigidindustries.com/d-series-pro-d-series.html.
I used the wire harness that came with it hook the switch to the park light fuse so they will come on when i turn the park lights on or when the automatic headlights turn on at night.
the supplied wiring harness comes with a relay and switch, the switch will have 3 wires going to it, mine was a white/blue/black wire, I cut the white wire (12v wire) coming from the relay to switch, connect the 12v wire and wedged it into one side of the 15amp parking light fuse that is in the fuse box next to battery. So the switch will be getting power from the parking light fuse, not from the relay. leave the white wire(12v) from relay connected to nothing( tape it off)  Leave the switch in the on position and the lights will come on whenever the park lights come one or when it is dark out they will turn on when the DRL senses it is getting dark. When in auto mode, the park light fuse is activated when its is dark out so no need to turn the park light on for the fog lights.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
