My driver's side rear brake on my '11 Yukon is making a creaky noise when activated and I'm out of ideas on the cause. I cleaned and lubricated both guide pins but it didn't help. Both pins slide as expected and don't make noise when moved manually. I pulled the caliper again today and inspected and cleaned the piston. The piston seals look fine with no leaking, bulges, etc. The piston surface cleaned up with brake cleaner and depressed easily prior to removal with a c-clamp. There aren't many moving parts so I'm out of ideas other than the entire caliper may be bad.
Here's a video with the tire off, truck on stands and my son depressing the pedal fully to the floor. It sounds like an old bed spring.
Any ideas are appreciated.
The fronts on my  '88 Firebird (with C4 HD swap) with Hawk pads started doing that ages ago and I never figured it out, figured some part of my assembly was off.  Then my 2016 Sliverado started doing it occasionally and I never touched them!  After doing the brakes on my truck it went away, so pads and rotors along with a little fresh disk brake lube were the only changes.
My current theory is the pads... but only because I greased the snot out of the Firebird brakes with no luck and I really doubt it could be the rotors!
Speaking of GM rotors, check out this wear pattern!
    I know recently doing mine own breaks the slide pins need to be in the correct order as far as Grooved on top smooth bottom or visa versa depending on your own vehicle and mine were out of wack and caused squeling and abnormal where but not until 20 30,000 miles did I start to notice.. hope this helps figured it was worth a reply
ABS Pump and or air in the line?  Did you grease the brake pads/shims?  But even that would not cause the issue in that video I think.
Last March we did the front brakes, the rears were done in 2017.  This March I had a piston on one of the front calipers fail to retract a little which caused a vibration.  Took  the wheel off, pushed the piston back in, cleaned and greased everything and all was well for a few months until one very hot day that same piston would not release and nearly set the truck on fire.  So my daughters and I replaced everything and then took a look at the rears, one piston was not retracting all the way and not wanting a repeat of the front, went ahead and rebuilt them ourselves and then used 6 quarts of brake fluid to flush and bleed the entire system manually and with our Tech-2.  Back to stopping on a dime.
GM offers no part numbers to rebuild the rear aluminum calipers, however, the pistons and seals for the front work perfect.  Use GM OE only as they are perfectly sized for the OE piston bore.  Aluminum calipers take the fine thread bleeder.  I have all part numbers if you need them and they are posted over at the TahoeYukon forum too.
Edited by swathdiver
Additional Information
I'm just doing this on the fly so I'm not sure if you read what I wrote about a similar issue with the slide pins look for your specific vehicle and make sure the smooth and the one with a groove are in the correct order IE groove top smooth bottom or vice versa and on top of that before buying a new caliper I would and again I'm not sure if you already have the red or did this make sure you lube up all the parts the piston the back of the back of the clipsall places that are going to get friction minus this goes without saying the pad surface that contacts the rotor I know I know but I just got to say it
I'm sorry, but I'm not following this at all.  Are you saying that the slide pins aren't round in every case?  By grooved or smooth I can only think that you're talking about the ends of the pins, the threaded end should have grooves to hold the dust boot and the other would be smooth, but they only go in one way.
The slide pins looked identical to me and made no noise when manually moving the caliper with the piston compressed to allow some movement while mounted. I've removed, cleaned and lubricated the pins twice with no change.
The sound appears to be coming from the caliper body when I listen with my ear next to the system. In my experience, failure to clean and lubricate the pad mounting surface on the caliper bracket would only cause squeal due to pad vibration.
The brakes were bled last summer but I may bleed this corner to make sure fluid is flowing through the caliper properly. There are no unusual marks on the rotor or pulling due to uneven braking.
I removed the pads, cleaned the caliper bracket and shims, lubed the shim surface and pad ears and reinstalled. No change.
But did you put in new pads or the old ones?  I bet the sound will stop with new pads... it doesn't make sense, but it seems like that's what did it for me.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
