Not really sure how to explain this one. I have a 94 K1500 4x4 350 TBI automatic. Has about 280k miles on it and still runs just fine until you really give it some gas. When I first got the truck, sitting in park if you stomped it the motor would get up to maybe 2k rpm then act like it had launch control or something and would just bounce at 2k snapping and popping. It came out of it for a while but its back to doing it whenever you give it a lil too much gas going down the road. The whole truck shakes and the motor snaps and pops. I replaced the plugs, coil, wires, cap/rotor air and fuel filter. Nothing has helped I figured maybe it was starving or choking out. I'm wondering if there could be an electrical issue as the temp gauge is almost as nuts as the tach cause one minute it will be running at like 110 then 260 then back to 150.
https://youtu.be/7uJp_0KwD2k
My dad was thinking maybe a stretched timing chain but as violent as that is, and it does this every time you accelerate unless you practically let it idle up to speed. I would think it would have jumped timing or something by now but it runs near mint normally just idling or cruising around.
I thought that myself for a bit but the motor mounts are pretty solid. Even then though I don't see how that could make the tach go nuts or the motor bounce in RPM or blow all the exhaust gaskets. It even expanded the muffler. The sound in the video is not the motor moving around that's the exhaust. Its blown out both manifold gaskets and expanded the muffler. Ive been tempted to unhook it and see if maybe the exhaust is clogged but I would think that would just make it bog rather than go completely insane.
Check fuel pressure while is running and under load, make sure it's within spec all the time.
This will be hard to check but the TBI injectors could also either not be sending out enough fuel or there are just like a fire hose causing you these issues. At idle the injectors should have a steady spray of fuel, if there are any solid drops of fuel then they are leaking and bad.
Check all your engine grounds for the battery and harness too. I would also check the distributor cap/rotor for corrosion and maybe even the gear on the end to make sure it's not worn out. Something is making the tach wig out and it likely deals with the way it gets it's tach signal.
Ive been considering tossing a 4bbl on it as that is what I am more used to. Truck will be getting a 454 next spring so I just need it to make one more Maine winter lol. I will do what I can to check the fuel pressure and stuff.
    • I was the GM of a Lincoln Mercury dealership back in the 80's. The service lot was always full with "broken" ones. Plenty of transmissions, power windows and a/c repairs. The only one I'd consider owning would be the Marauder at this point and it certainly wouldn't be a daily driver.  My 2025 GMC Sierra 1500 Denali Ultimate is my "Lincoln Town Car" in my retirement. I want all the "stuff". Big infotainment screens, one touch power windows, Supercruise (I won't buy another vehicle without it), hands free pretty much everything. I'm going to swap my current truck for a 2027 Yukon Denali Ultimate so I can have the air suspension and surround vision recording along with all the other "stuff".
    • Yep mine is on backorder also.
    • The Denali Ultimate's grille is tinted, but the "regular' Denali has a bright chrome grille like the current models.
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
