I have a couple of questions. If you have a 2017, could you take a picture of the 'upper' end of the cable where it mounts to the boxside and the actual bolt. I made hinges a couple of years and no longer have the OEM cables. Even though there is no binding on the trunnions w/ the hinges installed, I'm wonder if they are causing the less than stellar bushing life. More recent 1 didn't last 2 months before coming apart.
So I ordered new parts at the dealer & when I looked at the truck, the cables are too short & the bolts don't look anything like the parts on my brother's 2016.
PNs for the LH & RH cables & upper boxside bolts would be great for when I return to the dealer.
PS, they had the VIN of my truck when they looked up the parts.
2017 Sierra 2500HD base (work truck)
fd753cd16b1009759eb44bca36e97724.jpg8b92ee2ff6e029a9e031c7ae46eec447.jpg7423ee36644ba1c2b36244d285aff8ef.jpgbfa26758fc72ead7b9fe511984d5de23.jpg
Sent from the demons in my head
FWIW, mines an '18 sierra 2500  ( I don't think trim level changes the cables)
Cable, bolt and spacer look just like the pics dplarson posted
Sorry for the late reply and thank you!. Yes the parts the dealer ordered were the same as pictured. My concern was that my brother and nephew both have '16s which have a different cable. That cable has a 'keyhole' style hole @ the upper end & a 'retaining clip'. I'm guessing that the beancounters know that w/ the back up camera & tailgate lock harness making tailgate removal problematic, the older cable that allows for easy tailgate removal could be superceded.
Perhaps the need to use tools is a reminder to disconnect the harness that so many tailgates now have?
I wonder if the older cables could work on my 2017. I'd rather be able to remove the tailgate with no tools.
Of course I have not looked at how the cables disconnect, if they do that is.
Sent from my Pixel 4 XL using Tapatalk
I think the bolts would have to be replaced on the box side end.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
