Probably gonna remove the blocks between the axle and the leaf springs. But I want to see how it sits and rides with camper hooked up and my bike loaded in the bed.
34 minutes ago, Norman Dalisay said:
@mysery1 this’ me w/ the GM specific tires 285/45/22 for 22 inch wheels on a Belltech 1012SP Lowering kit 4/6 drop.. originally I had bigger tires which were 285/50/22 that rubbed up front & was way too bouncy; now it’s way better!
Nice to know about the tire size, thanks.
285/45/22 are the factory size.
Nice truck. I did not know what the factory size was for 22's. I believe mine came from the factory with 20's as that is what is on the sticker on the B column.
What size spare tire comes with a truck that came from the factory with 22's? The spare on my truck is a 17.
Thank you very much.
Scan the QR code in the drivers side door jamb, should tell what wheels it came with. RPO code.
6 hours ago, Norman Dalisay said:
I believe the spares are all 17s.. that’s what I have..
Yea, 17 should be the correct size, they are not going to give you an extra 20 or 22.
So I scanned the QR code and the truck originally came with 20's. I want to run LT tires for towing so I'm going to go back to the 20's. If 18's will fit I would consider putting a set of those on.
  • 1 month later...
It looks like I'm going with 18's as I have a better selection of tires. I want something with a fairly stiff sidewall when towing. The truck has 2" belltech drop spindles installed but this shouldn't be a problem per the installation instructions.
  • 1 month later...
I found a set of 20" takeoffs with 275/60R20 tires. I never liked the 22's that came with the truck. With a 2/3 drop and a tire diameter about 1 1/2 larger than 22's I like the look. The ride quality seems fine with a little more road noise which I expected due to more aggressive tread pattern and not being P rated. I have also had no issues with anything rubbing.
 1091004013_IMG_20210530_182641781_HDR(1).thumb.jpg.5eb9e2cfdc420c14bfdd839c67f1d773.jpg
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
