Anyone else running the aftermarket motofab upper control arms for 2.5"-3" leveling kit on your trucks?  I installed mine about 4-5 months and 10,000 miles ago and the bushings are failing.  Wondering if this is a common problem with these control arms.  I know they have not been in stock for quite some time didn't know if it was a supply issue or they were having problems similar to what I'm experiencing.  After reaching out to Motofab they did say they would send out new bushings waiting to see if it's the same bushings I have or better.  Just hate putting more money into it to have the same problem later.
Is Motofab sending the bushings at no cost? i would hope so at least.
I've been eyeing these control arms.  I hate to hear the bushings are failing this quickly.  Hopefully Motofab makes it right.
Are you running stock wheels?  Do the tires rub the UCA?
They were out of stock due to COVID for a while
I’m sad to hear about these bushings now because I just installed these the other day. 16 Silverado 4wd stock 18’s with 275/70r18 and 2.5” level, rubs front of control arm , need to figure out if I can run different arms or not. Not a huge fan of spacers
@TriZZZl3 not running stocks aftermarket 22" Hostile wheels with -24 offset I was planning on swapping out  for stocks during the winter but now a little concerned with @53boy post off rubbing on stock wheels.  Yes they did send the replacement bushings for free mo charge to me just concerned putting more time and money in the same product.  If anyone has any suggestions for a good quality aftermarket bushing for UCA let me know.. Thanks
  • 4 months later...
I installed these about two months ago.  Just started having issues in the last week.  The bushing on the left side is already failing.  I would stay away from these to be honest.  I haven’t reached out to Motofab yet, but hopefully they send replacements free of charge.  Even then, I hate to spend money on replacing them if they’re going to fail again.
Just wondering if you’ve had any issues with your UCAs?  One of the bushings on my left side is failing.
So far no. I can see one side of the front bushing starting to crack though. I’m almost positive I’ll be ditching these control arms within the year .
Sucks to spend money on something, only to have to replace it far sooner than expected.  Throw in the money for an alignment, and it makes it even worse.
Just curious if you installed the replacement bushings from Motofab, or if you went with a different one?  They are sending me replacements free of charge, but I'm wondering if I will be wasting money putting the same bushings back in there?  Thinking about biting the bullet, and getting Ready Lift UCAs instead.
Edited by jabba7
misspelling
The rough country upper control arms seem to be garbage to, installed the rough country 3 1/2 inch lift kit on my truck, in under a year both ball joints in the upper control arms were bad, Of course they sent me the ball joints, I had to swap out and redo alignment and now eight months later they’re bad again, they won’t warranty anything now and I want their crap off my truck, Time for new upper control arms! What’s the best answer or way to go?  anybody have input? Thanks
Edited by Harleyguy
1 minute ago, Harleyguy said:
The rough country upper control arms seem to be garbage to, but there are 3 1/2 inch lift kit on my truck, and under a year both ball joints in the upper control arms were bad, Of course they sent me the ball joints, I had to swap out and redo alignment and now eight months later they’re bad again, Time for new upper control arms! What’s the best answer anybody have input?
I'm looking at Ready Lift UCAs.  Hate that I just spent $300 on the Motofabs, and the cost to install.  However, I'm hesitant to install replacement bushings if they're just going to fail again.
I've had the Motofab UCAs installed for 3 months (on a 3" level) and have 0 issues to this point.
For myself, I'm very happy with them.
My Kryptonite UCA's have 25,000 miles and are like new. I give them a shot of silicone spray every month. I also hit everything that has a bushing . Leaf springs , sway bar, etc.
IMO these should have a grease zerk for each bushing.
So I'm thinking these bushing failures are from being bone dry.
The Motofab UCAs I have do have Zerk fittings and the installation instructions recommend not greasing upon install as they are pre-greased from the factory.
However, as with all bushings, they should be monitored over time in case new grease is required.
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
