When I remote start my 2020 Silverado 2500, the AC is on full blast. I was told I could modify that in my infotainment system, but that option is not available.  I was looking at the manual and see some options like folding the mirrors when locking doors and mine doesnt have that either.  It seems as if my infotainment system has a minimal amount of options.  I can't add apps either.
Any thoughts or suggestions?
Thanks in advance
I could be wrong but I'm pretty sure that the Custom trim level doesn't get a lot of the amenities that the higher level trims packages will have available within their infotainment systems.
yeah I think custom gets basic 7".....may have option for entry level 8"....but yes it wont have alot of features
I have the premium 8" info ( LT conv 1 and 2) and I cant fold my mirrors while locking the doors.....LTZ or HC gets it
Custom trim has limited personalization settings.  Remote power folding mirror operation is top trims only.
As for the HVAC:
Quote
#PIT5736A: Manual HVAC Settings During a Remote Start - Diagnostic Tip - (Oct 8, 2020)
Correction/Function:
Cold ambient temperature - below 50°F (10°C):
Mode = Defrost
Temperature = Full Hot
Blower = 8
Recirculation = Fresh Air
A/C compressor = Only commanded on if conditions allow compressor engagement.
Hot ambient temperature - above 59°F (15°C):
Mode = Panel Vents
Temperature = Full Cold
Blower =  8
Recirculation = Recirculate
A/C compressor = On
Mid ambient temperature - anything in between "cold" and "hot" ambient temperature values that are listed above:
Mode = Last known setting
Temperature = Last known setting
Blower =  Last known setting
Recirculation = Last known setting
A/C compressor = Last known setting
Note: On transition to ignition on following an RVS event, the HVAC settings will return to last known settings.
The only real extra you get is the option to lower windows with the remote. But it will lower them all the way and you can't make them go back up with the remote. So don't inadvertantly lower them on a rainy when you're trying to start it.
