Other than the pedal commander.  IMO, I wouldnt want to waste my money on that.  I'll just press the gas more.   I'm also waiting on the Banks programmer.   Anything else out?
Banks was working an a Derringer for the 3.0 but got confirmation today it's on hold. Partly due to covid, and partly due to lack of consumer interest. We need more people to show there's a want for this!
There was another company making one.  I forget the name.
Stealth was another one I saw but their website still says "in development" and have not heard back from them on eta.
I ended up making my own intake tube from the filter box to throttle body and noticed an immediate improvement in the mid range and daily driving. I also increased my exhaust size to 4" after the catalytic converter and only noticed a small change in exhaust tone.
I wouldn't mind hearing a little bit more turbo.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
