Hello I installed these yesterday. They look soooo good. Great upgrade for the 19-21 Silverado Custom, Trail Boss, or Work Truck
Edited by Sonny Durden
Add
  • Like 5
Looks good. Better than the yellow halogens. I surmise the headlights are still used as the DRL's instead of the strips? The only thing I've noticed on Spyder lights in the past is that the LED strips are more of a dim glow and not bright because they are florescent and not LED. Probably because they stay the same brightness day and night and not like the OEM DRL's which are bright (high power) during the day then go to low power at night. What high/low headlights are you running?  They come stock with halogens.
Edited by mafd2
10 minutes ago, mafd2 said:
Looks good. Better than the yellow halogens. I surmise the headlights are still used as the DRL's instead of the strips? The only thing I've noticed on Spyder lights in the past is that the LED strips are more of a dim glow and not bright. Probably because they stay the same brightness day and night and not like the OEM DRL's which are bright (high power) during the day then go to low power at night.
So the LED strips are not used as DRL. They only come on when you remote start the truck or when you actually turn the lights on. Since they are plug and play they utilize the low beam as the DRL just like the normal halogen lights
The strips are CCFL (florescent) and not LED. What high/low headlights are you running?
Edited by mafd2
So this housing calls for a H7 instead of a H11. It comes with those bulbs. I upgraded the H7 low beam with a LED by Beam Tech.
I didn’t know that they were florescent. They are pretty bright at night
Looks nice. Be sure you get hem aimed correctly. Go on an even slad and use mortar lines on a brick wall or similar to be sure they are same height. If you get flashed, bring them down a tad until the cut off line on the projectors is right. Not sure if you know but LED or HID headlights voids the warranty but I would've changed the halogens myself. Aftermarket LED headlights put out a lot of heat and have melted some housings.
one of first things i did was upgrade to LEDs.....mine worked out perfect as far as cutoff.....i used a wall like dude above said and almost identical, haven't been flashed once in 6 months and my truck sits pretty high....
my neighbors business upgrades sprinter vans into fancy overlander type vehicles and he brought a brand new one home other day and even that had halogens......those are 50-80k though this one was probably closer to 50k......still cant believe halogen even exist anymore
Do you have a photo of these lights in brighter light turned off? Trying to decide between these or HID retrofit
I like the look of these pretty good! Spyder quality has come a long way since I had a set on my 2009 Silverado.
I hate that GM went back to halogens on some T1 trims. Every K1 produced 2016+ had bixenon projectors - even the work trucks. Now someone who spends a lot of money on a Custom or Custom TB gets halogens? Bean counters at it again...
I think those look pretty good. Sort of have the 2500 style to them.  I'm glad to see aftermarket supplies jump on new opportunities.
I hope they are good. It wasn't exactly easy to replace them. LOL
I don't want to do it again anytime soon.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
