The other day I installed a 3" Fabtech lift on my dads 19 denali 6.2 with ARC. lift install went smoothly for the most part, one bad piece of hardware and poor instructions for a few things. interestingly enough the ones on the website differed from the printed ones in the kit.
Anyway my issue is now it has a vibration when over 55 mph while in Auto 4WD/AWD setting. soon as you hit the button for 2wd only it goes away.
Im hoping this just isnt an issue from the increased ride height and he can no longer run awd at speed. actually hoping i possibly did something wrong that caused the issue. but front halfshafts look good and not really at any extreme angle, there are no odd noises or clunking.
lift just consisted of 2.5" strut spacer and .5" spring preload spacer with new upper A arms. alignment came out pretty good no issues there. Tires are balanced correctly.
90+ in 2wd and not the slightest shake, but in auto it starts just about 55 and gets worse the faster you go.
any insight? diff drop kit to fix angles required? Something I may have blown it on with half shafts on install? (they didnt even come out just removed the hub nut to let them slide out of the hub a little to pull the knuckle out of the way.
Any one else have same lift on the same truck?
You shouldn’t really be driving around in auto on dry pavement but because the issue is present while engaged my first guess would be the angle of the front driveshaft.
I have read people tearing up there trucks because of these lift/level kits while using the awd, some kits actually warn of this in the fine print. Angles for ur driveshaft are not rite! A lift kit from bds or other decent kit will correct this with relocation brackets.
auto/AWD was designed to be run full time if wanted, but I am thinking front half shafts arent at a happy angle
bds only sold a 6" kit and thats too much.
3 hours ago, redwngr said:
Does that lift include parts to lower the front differential?
It does not, only 2.5" leveling spacer over the strut and a .5" spring preload spacer. does someone make a 1-2" diff drop kit?
They make 1.5,2.5, 4,6in kits
they only make 4' and 6" for denali with ARC
I have the Fabtech 3" with the loaded coils and shock combo.  I'm also getting a very slight vibration in AWD around 55-60.  Figured it was the 34" tires.  Also nothing in 2WD at any speed.  It just started snowing and the roads are getting icy/snowy.  Will post back once I get my truck back from the dealer for the window leak.  Not sure if it does the same thing in 4 high at those speeds in the snow yet but I'll let you know.  And yes I don't like to drive at those speeds in 4 high in the snow but straight downhill sections of road its hard to avoid it.
Wonder if the longer GM front axles on the factory 2" lift would fix the problem?
I wonder if this is a known issue that you get vibration in Auto for all the 3.5"-4" lifts out there or if this is a one off.
Edited by SilveradoRST
They’re spinning whether in 2 or 4 wheel drive so.... probably not?
Just got home from a day in the snow in the mountains.  In AWD there is a very slight vibration at 55 that didn't seem to get worse at higher speeds.  In 4 hi though nothing, smooth and easy.  Not sure why that is but it is.  Would still like to drop the diff to improve the axle angle.
Was thinking of the longer GM front axles in the factory TB lift but unless they're designed for greater angles it doesn't address the original problem.  Still haven't found an actual diff drop kit for the 2019/2020 trucks other than Ebay.
Discovered why there are no diff drop kits for a 2020.  Took the time to crawl under the truck and there is no way 4 small pucks of any design are going to lower the front diff.  The front differential is bolted into several frame pieces vertically and horizontally.  There is no way that I can see you'd be able to drop the front diff without some sort of subframe or without heavy modification.  Beware of any Ebay kit that says it fits with pucks/spacers and longer bolts.
  • 3 months later...
Has anyone found a fix for the new AWD/4wd vibration after installing front end lift or level?
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
