The other day I installed a 3" Fabtech lift on my dads 19 denali 6.2 with ARC. lift install went smoothly for the most part, one bad piece of hardware and poor instructions for a few things. interestingly enough the ones on the website differed from the printed ones in the kit.
Anyway my issue is now it has a vibration when over 55 mph while in Auto 4WD/AWD setting. soon as you hit the button for 2wd only it goes away.
Im hoping this just isnt an issue from the increased ride height and he can no longer run awd at speed. actually hoping i possibly did something wrong that caused the issue. but front halfshafts look good and not really at any extreme angle, there are no odd noises or clunking.
lift just consisted of 2.5" strut spacer and .5" spring preload spacer with new upper A arms. alignment came out pretty good no issues there. Tires are balanced correctly.
90+ in 2wd and not the slightest shake, but in auto it starts just about 55 and gets worse the faster you go.
any insight? diff drop kit to fix angles required? Something I may have blown it on with half shafts on install? (they didnt even come out just removed the hub nut to let them slide out of the hub a little to pull the knuckle out of the way.
Any one else have same lift on the same truck?
You shouldn’t really be driving around in auto on dry pavement but because the issue is present while engaged my first guess would be the angle of the front driveshaft.
I have read people tearing up there trucks because of these lift/level kits while using the awd, some kits actually warn of this in the fine print. Angles for ur driveshaft are not rite! A lift kit from bds or other decent kit will correct this with relocation brackets.
auto/AWD was designed to be run full time if wanted, but I am thinking front half shafts arent at a happy angle
bds only sold a 6" kit and thats too much.
3 hours ago, redwngr said:
Does that lift include parts to lower the front differential?
It does not, only 2.5" leveling spacer over the strut and a .5" spring preload spacer. does someone make a 1-2" diff drop kit?
They make 1.5,2.5, 4,6in kits
they only make 4' and 6" for denali with ARC
I have the Fabtech 3" with the loaded coils and shock combo.  I'm also getting a very slight vibration in AWD around 55-60.  Figured it was the 34" tires.  Also nothing in 2WD at any speed.  It just started snowing and the roads are getting icy/snowy.  Will post back once I get my truck back from the dealer for the window leak.  Not sure if it does the same thing in 4 high at those speeds in the snow yet but I'll let you know.  And yes I don't like to drive at those speeds in 4 high in the snow but straight downhill sections of road its hard to avoid it.
Wonder if the longer GM front axles on the factory 2" lift would fix the problem?
I wonder if this is a known issue that you get vibration in Auto for all the 3.5"-4" lifts out there or if this is a one off.
Edited by SilveradoRST
They’re spinning whether in 2 or 4 wheel drive so.... probably not?
Just got home from a day in the snow in the mountains.  In AWD there is a very slight vibration at 55 that didn't seem to get worse at higher speeds.  In 4 hi though nothing, smooth and easy.  Not sure why that is but it is.  Would still like to drop the diff to improve the axle angle.
Was thinking of the longer GM front axles in the factory TB lift but unless they're designed for greater angles it doesn't address the original problem.  Still haven't found an actual diff drop kit for the 2019/2020 trucks other than Ebay.
Discovered why there are no diff drop kits for a 2020.  Took the time to crawl under the truck and there is no way 4 small pucks of any design are going to lower the front diff.  The front differential is bolted into several frame pieces vertically and horizontally.  There is no way that I can see you'd be able to drop the front diff without some sort of subframe or without heavy modification.  Beware of any Ebay kit that says it fits with pucks/spacers and longer bolts.
  • 3 months later...
Has anyone found a fix for the new AWD/4wd vibration after installing front end lift or level?
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
