I couldn't find a description, so if its out there I've missed it.
what are the driveline components of a 4WD T1?
it can be set to 2WD, AWD, or 4WD modes which is just incredible, this is an amazing machine.
usually AWD would be an LSD in the rear and an open diff in the front. 4WD is usually a locked front. I found (just testing) that even in 4WD mode this truck can make a turn, so the front diff must not be locked. are they electronic lockers? able to detect when the front needs to be unlocked and does so automatically? I assume if its actually 4WD that should I have been making that turn on dirt or ice that I would have had a locked front and thus a real 4WD and somehow the truck is just smart enough to make it all work in every situation.
I've had an AWD truck that had an LSD in the rear and an open in the front, and a much older 4WD which I think had an LSD in the rear and the front locked when you moved the lever into the 4x4 position, in that position of course the truck could not turn because the front wheels were not able to rotate at different speeds. This truck doesn't have that problem.
This truck is just awesome, but the engineer in me wants to know how it does its thing. prior to my 2020 the newest truck I've owned was an 03...a lot has changed since then!
The 2WD is self explanatory.
The AWD means it will only engage the front axle when wheel slip in the rear is detected, otherwise it's running in 2WD. The front diff is open and the rear has a G80 style locker that only locks when one wheels has 100 or 150rpm speed difference.
4WD is going to be 4X4 all the time where the transfer case is engaged to the front axle, the front diff is still open. Yes you can still turn on pavement but it's not good for the components of the 4X4 system. It could have extra wear on the transfer case, front diff and the front tires. You'd noticed how bad it is if you tried to do a real tight 180 degree turn, it wouldn't want to move that freely.
    ballencd
    ballencd
  • Who's Online   6 Members, 1 Anonymous, 667 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
